Hi all, Im a beginner at programming and need a bit help. I downloaded my zip file from edge impulse and my ESP32 can detect now the two objects I trained it with. The next step I want to do is when Object 1 is detected → LED1 should turn on and if Object 2 is detected → LED2 should turn on. The hardware is already set up, I just need to know how and what I have to change in my code. This is the code: #include <Nano_vs_Uno_inferencing.h>
#include “edge-impulse-sdk/dsp/image/image.hpp”
#include “esp_camera.h”
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#else
#error “Camera model not selected”
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
.frame_size = FRAMESIZE_QVGA, //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
.fb_count = 1, //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
@brief Arduino setup function
void setup()
Serial.begin(115200);
while (!Serial);
Serial.println(“Edge Impulse Inferencing Demo”);
ei_printf(“Failed to initialize Camera!\r\n”);
else {
ei_printf(“Camera initialized\r\n”);
}ei_printf(“\nStarting continious inference in 2 seconds…\n”);
ei_sleep(2000);
@brief Get data and run inferencing
@param[in] debug Get debug info if true
void loop()
{// instead of wait_ms, we’ll wait on the signal, this allows threads to cancel us…
return;
}snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
if(snapshot_buf == nullptr) {
ei_printf(“ERR: Failed to allocate snapshot buffer!\n”);
return;
}ei::signal_t signal;
signal.get_data = &ei_camera_get_data;if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
ei_printf(“Failed to capture image\r\n”);
free(snapshot_buf);
return;
}// Run the classifier
ei_impulse_result_t result = { 0 };EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
ei_printf(“ERR: Failed to run classifier (%d)\n”, err);
return;
}// print the predictions
ei_printf(“Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n”,
ei_printf(“Object detection bounding boxes:\r\n”);
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#else
ei_printf(“Predictions:\r\n”);
ei_printf(" %s: “, ei_classifier_inferencing_categories[i]);
ei_printf(”%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
ei_printf(“Anomaly prediction: %.3f\r\n”, result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
ei_printf(“Visual anomalies:\r\n”);
for (uint32_t i = 0; i < result.visual_ad_count; i++) {
ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
continue;
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#endif
free(snapshot_buf);
@brief Setup image sensor & start streaming
@retval false if initialisation failed
bool ei_camera_init(void) {if (is_initialised) return true;
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
if (err != ESP_OK) {
return false;
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
s->set_vflip(s, 1);
s->set_awb_gain(s, 1);
#endif
is_initialised = true;
return true;
@brief Stop streaming of sensor data
void ei_camera_deinit(void) {//deinitialize the camera
esp_err_t err = esp_camera_deinit();if (err != ESP_OK)
ei_printf(“Camera deinit failed\n”);
return;
}is_initialised = false;
return;
- @brief Capture, rescale and crop image
- @param[in] img_width width of output image
- @param[in] img_height height of output image
- @param[in] out_buf pointer to store output image, NULL may be used
if ei_camera_frame_buffer is to be used for capture and resize/cropping. - @retval false if not initialised, image captured, rescaled or cropped failed
bool do_resize = false;
if (!is_initialised) {
return false;
if (!fb) {
return false;
esp_camera_fb_return(fb);
if(!converted){
ei_printf(“Conversion failed\n”);
return false;
do_resize = true;
if (do_resize) {
out_buf,
EI_CAMERA_RAW_FRAME_BUFFER_COLS,
out_buf,
img_width,
img_height);
return true;
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
// Swap BGR to RGB here
// due to https://github.com/espressif/esp32-camera/issues/379
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
#error “Invalid model for current sensor”
#endif
Project nr: 487107
