I’m trying to get the Keyword detection code running for Esp32-s3 (N16R8) Dev Kit C v1 but the code keeps resetting my esp32 when it reaches the recording part(after Starting continuous inference in 2 seconds…).I have tried changing nothing just importing the zip file and then uploading the es32 example, but the problem still occurs. i suspect this is a lack of memory problems but the logs show nothing related to that
- Platform: ESP32
- OS Version: Window 11
- Edge Impulse Version (Firmware):
#define EI_STUDIO_VERSION_MAJOR 1
#define EI_STUDIO_VERSION_MINOR 66
#define EI_STUDIO_VERSION_PATCH 1
Project Version: 1.0.9
Flash Info:
Chip Size : 16777216 B (16 MB)
Block Size : 65536 B ( 64.0 KB)
Sector Size : 4096 B ( 4.0 KB)
Page Size : 256 B ( 0.2 KB)
Bus Speed : 80 MHz
Bus Mode : QIO
Partitions Info:
nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
app0 : addr: 0x00010000, size: 1280.0 KB, type: APP, subtype: OTA_0
app1 : addr: 0x00150000, size: 1280.0 KB, type: APP, subtype: OTA_1
spiffs : addr: 0x00290000, size: 1408.0 KB, type: DATA, subtype: SPIFFS
coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
Compile Date/Time : Dec 27 2024 00:18:30
Compile Host OS : windows
ESP-IDF Version : v5.3.2-174-g083aad99cf-dirty
Arduino Version : 3.1.0
Board Info:
Arduino Board : ESP32S3_DEV
Arduino Variant : esp32s3
Arduino FQBN : esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=verbose,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default
============ Before Setup End ============
[ 487][V][esp32-hal-uart.c:421] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(44) txPin(43)
[ 496][V][esp32-hal-uart.c:510] uartBegin(): UART0 not installed. Starting installation
[ 505][V][esp32-hal-uart.c:575] uartBegin(): UART0 initialization done.
Inferencing settings:
Interval: 0.062500 ms.
Frame size: 16000
Sample length: 1000 ms.
No. of classes: 2
Starting continious inference in 2 seconds...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403787f8
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x1188
load:0x403c8700,len:0x4
load:0x403c8704,len:0xbf0
load:0x403cb700,len:0x30e4
entry 0x403c88ac
[ 0][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4200fb20
[ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4200faec
[ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4200fab8
[ 34][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4200fa84
[ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4200fb20
[ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4200faec
[ 68][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4200fab8
[ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4200fa84
[ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x4200fb20
[ 102][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x4200faec
[ 114][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x4200fab8
[ 125][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x4200fa84
[ 142][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 44 successfully set to type UART_RX (2) with bus 0x3fc94208
[ 152][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type UART_TX (3) with bus 0x3fc94208
=========== Before Setup Start ===========
Flash Info:
Bus Speed : 80 MHz
Bus Mode : QIO
Partitions Info:
Software Info:
Board Info:
Frame size: 16000
No. of classes: 2
