June 2021 Edge-Impulse -Cli installation Issues
Anyone getting any recent errors (June 22, 2021) installing the Edge Impulse Client?
AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\Release\bindings.node
was compiled against a different Node.js version using
NODE_MODULE_VERSION 72. This version of Node.js requires
NODE_MODULE_VERSION 88. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
Getting it for Node version 14. and a recent node version 15.10.0
Any suggestions?
Solved it by installing the most current Node at https://nodejs.org/en/download/current/
node-v16.3.0-x64.msi
Now getting errors on flash_windows.bat that say
If you see a ModuleNotFoundError error, run the following commands to add Python packages
     python -m pip install pyserial>=3.4
     python -m pip install inquirer>=2.7.0
but of course those don’t install. I updated windows Python but still no luck. Any suggestions?
Hi @Rocksetta,
Can you provide the full output when running the bat script?
On the Node issue, Node 14 is the recommended version as it’s the LTS version. I would suggest trying this withe Node 14:
npm uninstall -g edge-impulse-cli --force
This should force the bindings module to recompile from sources.
@Rocksetta After updating Node.js you’ll need to reinstall / upgrade the CLI as it has a binary component that needs to be recompiled.
@aurel Does edge-impulse-cli have a way to print the version number?
I often use the following for testing installations:
arduino-cli version
node -v
npm -v
west --version
mbed-cli --version
make --version
arm-none-eabi-gcc --version
python --version
PATH
The Linux tools have a version flag, will make sure we add it to the rest of the CLI tools. Version is printed when you first launch the daemon or uploader though:
$ edge-impulse-daemon
Edge Impulse serial daemon v1.13.6
edit: This will be fixed in CLI version 1.13.8.
