Hello guys,
I have been working on a project to run EI linux object detection model on Jetson nano using balena. I have been following this link from EI and this from balena. I am able to run sample app like smokeparticles running on balena os. I could install edge-impulse-linux but can’t run it. It says failed to start device monitor. I followed the instruction under troubleshooting guide and gave access to entire root folder. But still no luck. Has anyone done this work before or provide me any guidance? My repo is here .
Hi @mithundotdas,
It seems Adam has pointed you to our Balena contact, please let us know how that goes!
Hello @mithundotdas,
Is this the same error that you encountered some time ago for your “Building an AI-Powered Bird Watcher with Balena and Edge Impulse” project? This sounds familiar but maybe it is a different issue…
What kind of camera are you using? USB or CSI?
@gy4nt you had any issue with the the Jetson’s camera on Balena in the past?
@louis i still didn’t have time to test Jetson Nano + Edge Impulse!
@mithundotdas could you please share more details about your set up? what camera do you use? Maybe it’s a good idea to check here to get more information.
looking fwd to see this running
@louis I checked my old emails and it was different error on Pi 4. Initially we got “Unsupported architecture …” and then “No camera found”. On Jetson, the error is different. I am using USB camera. Verbose does not reveal any further error message.
root@143a076:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 045e:0772 Microsoft Corp. LifeCam Studio
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@143a076:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# edge-impulse-linux --verbose --disable-microphone
Edge Impulse Linux client v1.3.1
? What is your user name or e-mail address (edgeimpulse.com)? xxxx@gmail.com
? What is your password? [hidden]
? To which project do you want to connect this device? Mithun / jetson_nano
Failed to initialize linux tool Error code was not 0: Probing devices...
Failed to start device monitor!
A02 with SD card. Not sure if I am answering your question
What happens if you remove the docker-compose, bring your Dockerfile up to the root directory, and re-push it @mithundotdas?
@dtischler I started with that Then moved to docker-compose to add privilege flag to true and host to network.
Aha - gotcha. I’m wondering if CAP_SYS_ADMIN
and/or CAP_SYS_RAWIO
might be needed when using a Compose. I’m not totally sure, so it would basically be just a “try it and see what happens” test, ha!
Having some trouble pushing to balena right now. May be my network acting up. Will update when it’s done with above suggested change.
Hi @mithundotdas,
I just thought of something, can you do that and check if it works:
$> whoami
your-username
$> chown -R your-username:your-username ~/.config
I had the same error during a workshop using the Jetson Nano: https://github.com/edgeimpulse/workshop-advantech-jetson-nano
Let me know,
@louis @dtischler I tried both but still same issue. Not sure what I am missing.
root@143a076:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# whoami
root
root@143a076:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# chown -R root:root ~/.config
? What is your user name or e-mail address (edgeimpulse.com)? mithundotdas@gmail.com
And in docker-compose , I have
version: '2.1'
services:
inference:
build: ./inference
privileged: true
restart: always
network_mode: host
container_name: inference
cap_add:
- CAP_SYS_ADMIN
- CAP_SYS_RAWIO
ports:
- 8080
labels:
io.balena.features.dbus: '1'
io.balena.features.kernel-modules: '1'
volumes:
- 'shared-data:/var/data'
- 'shared-media:/var/media'
environment:
- UDEV=1
devices:
- '/dev:/dev'
volumes:
shared-data:
shared-media:
I’m not even able to complete the Nano installation for some reason, I am failing on the vips-8.10.5
compilation.
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -I../../libvips/include -DG_DISABLE_ASSERT -DG_DISABLE_CHECKS -pthread -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include -g -O2 -MT im_gradcor.lo -MD -MP -MF .deps/im_gradcor.Tpo -c im_gradcor.c -o im_gradcor.o >/dev/null 2>&1
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -I../../libvips/include -DG_DISABLE_ASSERT -DG_DISABLE_CHECKS -pthread -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include -g -O2 -MT im_gaddim.lo -MD -MP -MF .deps/im_gaddim.Tpo -c im_gaddim.c -o im_gaddim.o >/dev/null 2>&1
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -I../../libvips/include -DG_DISABLE_ASSERT -DG_DISABLE_CHECKS -pthread -I/usr/include/glib-2.0 -I/usr/lib/aarch64-linux-gnu/glib-2.0/include -g -O2 -MT vips7compat.lo -MD -MP -MF .deps/vips7compat.Tpo -c vips7compat.c -o vips7compat.o >/dev/null 2>&1
make[3]: Leaving directory '/usr/local/cuda-10.2/samples/bin/aarch64/linux/release/vips-8.10.5/libvips/deprecated'
Makefile:876: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/usr/local/cuda-10.2/samples/bin/aarch64/linux/release/vips-8.10.5/libvips'
Makefile:629: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/usr/local/cuda-10.2/samples/bin/aarch64/linux/release/vips-8.10.5'
Makefile:536: recipe for target 'all' failed
make: *** [all] Error 2
Worked around that by just updating to https://github.com/libvips/libvips/releases/tag/v8.12.2
instead.
Camera is definitely detected by the system, but, for some reason EI won’t locate it…
At the end of this giant log below, I just disable camera, and it launches (though this defeats the purpose obviously LOL)
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/releasroot@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# edge-impulse-linux --disable-microphone --verbose
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! video/x-raw ! videoconvert ! jpegenc ! multifilesink location=test%05d.jpg
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:02.438842340
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# ls
clock node-v12.13.0-linux-arm64 postProcessGL smokeParticles vips-8.10.5.tar.gz vips-8.12.2.tar.gz
deviceQuery node-v12.13.0-linux-arm64.tar.xz simpleGL test00000.jpg vips-8.10.5.tar.gz.1
jetson.sh node-v12.13.0-linux-arm64.tar.xz.1 simpleTexture3D vips-8.10.5 vips-8.12.2
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# v4l2-ctl --list-formats-ext --device /dev/video0
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
<snip>
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2304x1536
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.017s (60.000 fps)
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# GST_DEBUG=2 gst-device-monitor-1.0
Probing devices...
0:00:00.128048333 723 0x557cf82a00 WARN default gstdevicemonitor.c:458:gst_device_monitor_start:<devicemonitor0> No filters have been set, will expose all devices found
0:00:00.268884896 723 0x557cf82a00 ERROR pulse pulsedeviceprovider.c:439:gst_pulse_device_provider_start:<pulsedeviceprovider0> Failed to connect: Connection refused
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# gst-device-monitor-1.0
Probing devices...
Device found:
name : Logitech Webcam C925e Analog Stereo
class : Audio/Source
caps : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
properties:
alsa.resolution_bits = 16
device.api = alsa
device.class = sound
alsa.class = generic
alsa.subclass = generic-mix
alsa.name = "USB\ Audio"
alsa.id = "USB\ Audio"
alsa.subdevice = 0
alsa.subdevice_name = "subdevice\ \#0"
alsa.device = 0
alsa.card = 2
alsa.card_name = "Logitech\ Webcam\ C925e"
alsa.long_card_name = "Logitech\ Webcam\ C925e\ at\ usb-70090000.xusb-2\,\ high\ speed"
alsa.driver_name = snd_usb_audio
device.bus_path = platform-70090000.xusb-usb-0:2:1.2
sysfs.path = /devices/70090000.xusb/usb1/1-2/1-2:1.2/sound/card2
udev.id = usb-046d_Logitech_Webcam_C925e_279866DF-02
device.bus = usb
device.vendor.id = 046d
device.vendor.name = "Logitech\,\ Inc."
device.product.id = 085b
device.product.name = "Logitech\ Webcam\ C925e"
device.serial = 046d_Logitech_Webcam_C925e_279866DF
device.form_factor = webcam
device.string = front:2
device.buffering.buffer_size = 256000
device.buffering.fragment_size = 128000
device.access_mode = mmap+timer
device.profile.name = analog-stereo
device.profile.description = "Analog\ Stereo"
device.description = "Logitech\ Webcam\ C925e\ Analog\ Stereo"
alsa.mixer_name = "USB\ Mixer"
alsa.components = USB046d:085b
module-udev-detect.discovered = 1
device.icon_name = camera-web-usb
gst-launch-1.0 pulsesrc device=alsa_input.usb-046d_Logitech_Webcam_C925e_279866DF-02.analog-stereo ! ...
Device found:
name : Monitor of Built-in Audio Analog Stereo
properties:
device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
device.class = monitor
alsa.card = 1
alsa.card_name = tegra-snd-t210ref-mobile-rt565x
alsa.long_card_name = tegra-snd-t210ref-mobile-rt565x
device.bus_path = platform-sound
sysfs.path = /devices/sound/sound/card1
device.form_factor = internal
device.string = 1
device.icon_name = audio-card
gst-launch-1.0 pulsesrc device=alsa_output.platform-sound.analog-stereo.monitor ! ...
Device found:
name : Built-in Audio Analog Stereo
properties:
device.api = alsa
alsa.name = ""
alsa.id = "ADMAIF1\ CIF\ ADMAIF1-0"
alsa.subdevice = 0
alsa.device = 0
alsa.card = 1
device.string = front:1
device.buffering.buffer_size = 32768
device.buffering.fragment_size = 16384
device.description = "Built-in\ Audio\ Analog\ Stereo"
gst-launch-1.0 pulsesrc device=alsa_input.platform-sound.analog-stereo ! ...
Device found:
class : Audio/Sink
properties:
device.api = alsa
alsa.name = ""
alsa.subdevice = 0
alsa.device = 0
alsa.card = 1
gst-launch-1.0 ... ! pulsesink device=alsa_output.platform-sound.analog-stereo
Device found:
class : Video/Source
caps : video/x-raw, format=(string)YUY2, width=(int)2304, height=(int)1536, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)2/1;
video/x-raw, format=(string)YUY2, width=(int)2304, height=(int)1296, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)2/1;
video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
video/x-raw, format=(string)YUY2, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)320, height=(int)180, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
video/x-raw, format=(string)YUY2, width=(int)160, height=(int)90, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)1600, height=(int)896, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 60/1, 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)320, height=(int)180, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
image/jpeg, width=(int)160, height=(int)90, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 24/1, 20/1, 15/1, 10/1, 15/2, 5/1 };
properties:
udev-probed = true
device.bus_path = platform-70090000.xusb-usb-0:2:1.0
sysfs.path = /sys/devices/70090000.xusb/usb1/1-2/1-2:1.0/video4linux/video0
device.bus = usb
device.subsystem = video4linux
device.vendor.name = 046d
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video0
v4l2.device.driver = uvcvideo
v4l2.device.card = "Logitech\ Webcam\ C925e"
v4l2.device.bus_info = usb-70090000.xusb-2
v4l2.device.version = 264588 (0x0004098c)
v4l2.device.capabilities = 2216689665 (0x84200001)
v4l2.device.device_caps = 69206017 (0x04200001)
gst-launch-1.0 v4l2src ! ...
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# v4l2-ctl --list-devices
Logitech Webcam C925e (usb-70090000.xusb-2):
/dev/video0
root@37574b37dde9:/usr/local/cuda-10.2/samples/bin/aarch64/linux/release# edge-impulse-linux --disable-camera --disable-microphone
? What name do you want to give this device? Nano-2gb
[WS ] Device "Nano-2gb" is now connected to project "Jetson"
[WS ] Go to https://studio.edgeimpulse.com/studio/80308/acquisition/training to build your machine learning model!
Hello @dtischler,
instead.
This is strange, where did you get the jetson.sh
installation script? In our documentation, we changed in december the jetson.sh to use vipsv8.12.1
. Maybe I forgot to change the link somewhere…
Unfortunately I don’t have a Jetson Nano with me today so I cannot try. I will try tomorrow on my Jetson Nano 2G and Balena to see if I can reproduce the issue.
Thanks @louis! Looking closer at the versioning issue, that was my bad, I already had jetson.sh
on my local machine, and just copied it straight in…Now looking closer at the version sitting at https://cdn.edgeimpulse.com/firmware/linux/jetson.sh
I see it has indeed been updated to a newer version. So, that was my bad for going with what I already had, ha!
But yep, once you have your Nano setup, I am curious to see what results you get.
This is interesting. Someone found similar issue on Raspberry Pi 4 . https://github.com/just4give/balena-edge-impulse-linux/issues/10
That someone is a balena team member,
