Issues with "tensor arena", in object detection example
I am facing issues with the edge impulse devloped object detection model, which I am running on esp32 cam module. I have trained the model with 2 animal’s, labled as “Tiger and Elephant”.
Now as I have generate the Arduino library and putted it inside the IDE. In the library itself, there is a example folder from which I took the “esp_camera example”. I am also putting the example below, kindly check. For further details about the errors please check “Summery” section below.
//Edge Impulse Arduino examples
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
#include <EliTrg_detect_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
    Serial.begin(115200);
    while (!Serial);
    else {
    ei_sleep(2000);
* @param[in]  debug  Get debug info if true
void loop()
        return;
    if(snapshot_buf == nullptr) {
        return;
    ei::signal_t signal;
        free(snapshot_buf);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Object detection bounding boxes:\r\n");
        if (bb.value == 0) {
            continue;
        ei_printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#else
    ei_printf("Predictions:\r\n");
        ei_printf("  %s: ", ei_classifier_inferencing_categories[i]);
        ei_printf("%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
    ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
    ei_printf("Visual anomalies:\r\n");
    for (uint32_t i = 0; i < result.visual_ad_count; i++) {
        ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
            continue;
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    if (err != ESP_OK) {
      return false;
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
    bool do_resize = false;
    if (!is_initialised) {
        return false;
    if (!fb) {
        return false;
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
        do_resize = true;
    if (do_resize) {
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        out_buf,
        img_width,
        img_height);
    return true;
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        // Swap BGR to RGB here
        // due to https://github.com/espressif/esp32-camera/issues/379
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#endif
I am trying to build a project to integrate PIR, sleep mode with AI on ESP32 CAM module, to reduce battery usage and extend the battery life.
Summary:
Now about the issue, I am continuously getting the below given errors on the serial monitor.
17:09:33.284 -> Predictions (DSP: 14 ms., Classification: 2291 ms., Anomaly: 0 ms.):
17:09:33.284 -> Object detection bounding boxes:17:09:33.687 -> ERR: Failed to allocate persistent buffer of size 192, does not fit in tensor arena and reached EI_MAX_OVERFLOW_BUFFER_COUNT
17:09:33.687 -> ERR: Failed to allocate persistent buffer of size 32, does not fit in tensor arena and reached EI_MAX_OVERFLOW_BUFFER_COUNT
17:09:33.687 -> ERR: Failed to allocate persistent buffer of size 128, does not fit in tensor arena and reached EI_MAX_OVERFLOW_BUFFER_COUNT
17:09:33.687 -> ERR: Failed to allocate persistent buffer of size 12, does not fit in tensor arena and reached EI_MAX_OVERFLOW_BUFFER_COUNT
17:09:35.702 -> Predictions (DSP: 14 ms., Classification: 2291 ms., Anomaly: 0 ms.):
17:09:35.702 -> Object detection bounding boxes:
As you can see in the log above the issue is with “tensor arena”, so I checked the files and tried changing what all is understandable to me, But nothing seems to work. I even tried directly defining it in the main code, given above, but that also didn’t worked.
Expected Results:
Print the lables of the objects detected in the serial monitor
Actual Results:
Errors in memory allocation with tensor arena.
  • Platform: [ESP 32 CAM module (CAMERA_MODEL_AI_THINKER).
  • Build Environment Details: Arduino IDE 2.3.6
  • OS Version: Windows 10 and 11
I have given all the required details in the above section.
Kindly guide me with this as I have tried with all the knowldege I have. This is the first time I am using edge impules so if I am doing any minor mistake, kindly let me know.
Thank you.
I saw this post and would like to follow it to see if you get a resolution. I recently posted this issue, which also relates to object detection and tensor arena. Hoping we both can find resolution.
Sorry I can’t help more directly. I’m currently trying to experiment with tweaking what the “malloc_addblock((void*)0x30000000, 288 * 1024);” does in my code, hoping it may be related to the root cause of what I’m seeing.
I’m wondering if your “Failed to allocate persistent buffer” may also relate to this line in your code, simply because I see you have this line of code: “snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);”
Wish I had more knowledge and expertise to help more. Best of luck, will watch to see if you can resolve this.
@BrianMacG , No issue, I am also new to this. I tried to increase the tensor arena in the code directly and in a file name “model_metadata.h”, where it is defiined as “#define EI_CLASSIFIER_TFLITE_LARGEST_ARENA_SIZE 1093964”. I tried changing it but nothing seems to work. I tried other experimental stuff but it lead me to other issues. I hope we both get the resolution for this issue.
Thank you.
Hi @BrianMacG,
I went through the process all over again. I created a new project and did the whole process again from scratch, the only change I did was I reduced the number of images this time, like if it was 5000 last time then I straight went down to 500 or 1000 images. Didn’t found the exact issue but some how with the new model the error was resolved. And I even checked the tensorflow arena size in the file it was reduced.
So the issue could be with huge dataset or some other bug. It worked for me to start over again, might work for you and other who are struggeling. Try and let me know. I will still try to get into the roots of the issue or we might get the solution from someone else.
Kindly note who will be reading this, it is not the exact solution for the root cause. It was just a hit and miss trial that I caried out, might work for you or might not. I ask the experts to look into this issue and help us resolve this.
Thank you.
Really appreciate your follow up. You’ve inspired me to do the same. The only thing that makes me concerned is the number of images you mentioned. My model used around only around 200 images, and still ran into this issue. You’re mentioning reducing from 5000 downwards to 1000.
Anyways, I’ll give it a shot. Did you select 96x96 image size, or reduce that to 48x48?
B
yes @BrianMacG, regarding image size, I am using 96 x 96 this time. Last time the images were not fine tuned, I picked a random dataset. This time I took some time looked what fits best and then did it. I think in last dataset as their was no resizing of the images that might have arose this problem, but as you are saying that your images were resized so again this must not be the issue.
This is getting more confussing, lets see what your results say.
Thankyou.
