Issues with installing edge-impulse-cli on MacOS Big Sur (11.2)
I can not get edge-impulse-cli installed on macOS Big Sur (11.2)
here is my terminal output, the installation just hangs on the last line:
% sudo npm install -g edge-impulse-cli
⸨ ⸩ ⠙ reify:rxjs: timing reifyNode:node_modules/edge-impulse-cli Completed in 2405ms
@gpolder, on macOS I’d recommend not using sudo. Can you give it another try without that?
I need sudo, as I don’t have write access to /usr/local/lib/node_modules/
  $ npm install -g edge-impulse-cli
    npm notice
    npm notice New minor version of npm available! 7.5.3 -> 7.6.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v7.6.0
    npm notice Run npm install -g npm@7.6.0 to update!
    npm notice
    npm ERR! code EACCES
    npm ERR! syscall mkdir
    npm ERR! path /usr/local/lib/node_modules/edge-impulse-cli
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/edge-impulse-cli'
    npm ERR! [Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/edge-impulse-cli'] {
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'mkdir',
    npm ERR! path: '/usr/local/lib/node_modules/edge-impulse-cli'
    npm ERR! }
    npm ERR!
Hi @gpolder,
You can change the owner of the node_modules directory as mentioned in the documentation:
sudo chown -R $USER /usr/local/lib/node_modules
Let us know if that helps,
thanks for the quick response.
deprecated warnings still remain, but otherwise the installation was successful.
Thanks for helping out.
I was also below process but still .I’m unable to install CLI
  • uninstalling
  • sudo chown -R $USER /usr/local/lib/node_modules
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated request@2.88.0: request has been deprecated, see
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
/usr/local/bin/edge-impulse-blocks -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/blocks.js
/usr/local/bin/edge-impulse-uploader -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/uploader.js
/usr/local/bin/edge-impulse-daemon -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/daemon.js
/usr/local/bin/edge-impulse-data-forwarder -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/data-forwarder.js
/usr/local/bin/edge-impulse-run-impulse -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/run-impulse.js
/usr/local/bin/eta-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/eta-flash-tool/flashtool.js
/usr/local/bin/edge-impulse-framebuffer2jpg -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/framebuffer-to-jpg.js
/usr/local/bin/himax-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/himax-flash-tool/flashtool.js
@serialport/bindings@8.0.8 install /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install EACCES: permission denied, access ‘/Users/ayushkhandelwal/.npm’
gyp WARN EACCES current user (“nobody”) does not have permission to access the dev dir “/Users/ayushkhandelwal/Library/Caches/node-gyp/14.18.0”
gyp WARN EACCES attempting to reinstall using temporary dev dir “/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/.node-gyp”
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/.node-gyp’
gyp ERR! System Darwin 20.3.0
gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
gyp ERR! node -v v14.18.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN tsargs@1.4.1 requires a peer of typescript@^3.1.6 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /Users/ayushkhandelwal/.npm/_logs/2021-10-05T10_04_27_986Z-debug.log
@Ayushkh you should never use sudo on macOS, it screws up stuff…
You probably want to fix permissions via:
$ sudo chown -R $USER /usr/local/lib/node_modules
$ sudo chown -R $USER ~/.npm
$ sudo chown -R $USER /Users/ayushkhandelwal/Library/Caches/node-gyp
Then:
$ npm install edge-impulse-cli -g
(no sudo on the last one)
Still not working…
ayushkhandelwal@Ayushs-MacBook-Pro ~ % npm uninstall -g edge-impulse-cli
up to date in 0.035s
ayushkhandelwal@Ayushs-MacBook-Pro ~ % sudo chown -R $USER /usr/local/lib/node_modules
ayushkhandelwal@Ayushs-MacBook-Pro ~ % sudo chown -R $USER ~/.npm
ayushkhandelwal@Ayushs-MacBook-Pro ~ % sudo chown -R $USER /Users/ayushkhandelwal/Library/Caches/node-gyp
ayushkhandelwal@Ayushs-MacBook-Pro ~ % npm install edge-impulse-cli -g
prebuild-install WARN install No prebuilt binaries found (target=14.18.0 runtime=node arch=x64 libc= platform=darwin)
No receipt for ‘com.apple.pkg.CLTools_Executables’ found at ‘/’.
No receipt for ‘com.apple.pkg.DeveloperToolsCLILeo’ found at ‘/’.
No receipt for ‘com.apple.pkg.DeveloperToolsCLI’ found at ‘/’.
gyp: No Xcode or CLT version detected!
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:400:28)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /Users/ayushkhandelwal/.npm/_logs/2021-10-05T10_28_34_649Z-debug.log
It just work after I installed node with NVM
After I looked into this issue
forum :- error-could-not-locate-the-bindings-file/2286/5
Then I run the commons I suggested
Then I used --force to installed
npm install -g edge-impulse-cli --force
npm WARN using --force Recommended protections disabled.
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See .
added 299 packages, and audited 300 packages in 1m
12 packages are looking for funding
run npm fund for details
3 vulnerabilities (1 low, 1 moderate, 1 high)
To address all issues (including breaking changes), run:
npm audit fix --force
Run npm audit for details.
npm notice
npm notice New patch version of npm available! 7.24.0 -> 7.24.2
npm notice Run npm install -g npm@7.24.2 to update!
npm notice
Still show the waring but get installed.
Thank you for quick Response
Cheers :slight_smile:
