Project ID: Dog Doorbell - Dashboard - Edge Impulse
I am attempting to compile this project using your provided C SDK. It gets compiled to WASM (using an in-house toolchain — I cannot use the WASM deployments you provide) successfully using the CMake file below. I have successfully used the same CMake file to compile and run the Motion Recognition example you provide (Motion recognition with anomaly detection - Edge Impulse Documentation).
I am now attempting to do the same with the vision model I created. To simplify things, I am providing an all black frame just to see if I can get inference running (baby steps!), but when I run inference I get this error:
Running impulse...
ERR: input tensor has size 4 bytes, but input matrix has has size 307200 bytes
run_classifier returned: -24
Begin output
[0.00000]
End output
I am preparing my input sample using the following methods:
static float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
static size_t feature_ix = 0;
// helper to pack RGB888 into a float’s mantissa (0xRRGGBB)
static inline float pack_rgb888_u32_to_f32(uint8_t r, uint8_t g, uint8_t b) {
uint32_t u = ((uint32_t)r << 16) | ((uint32_t)g << 8) | (uint32_t)b;
float f;
memcpy(&f, &u, sizeof(f));
return f;
int get_feature_data(size_t offset, size_t length, float *out_ptr) {
printf("get_feature_data: offset=%lu, length=%lu\n", offset, length);
return 0;
and
for (int i = 0; i < EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT; i++) {
features[feature_ix++] = pack_rgb888_u32_to_f32(0, 0, 0);
signal_t signal;
signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT; // 102400
signal.get_data = &get_feature_data;
ei_impulse_result_t result;
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, true);
printf("run_classifier returned: %d\n", res);
printf("Begin output\n");
Here’s the CMake file I am using:
cmake_minimum_required(VERSION 3.20.0)
# Set the WASI SDK toolchain file
set(CMAKE_TOOLCHAIN_FILE /opt/wasi-sdk/share/cmake/wasi-sdk-p1.cmake)
# Set build type to Release
set(CMAKE_BUILD_TYPE Release)
# Project name
set(APPNAME edge-impulse-standalone)
project(${APPNAME})
# Set compilation flags
add_compile_options(
# --target=wasm32-wasi
-Os
-DNDEBUG
-Wall
-DEI_PORTING_POSIX=1 # Force POSIX port for WASM
-DUSE_CMSIS_NN=OFF # Compiling for OSX
-DEI_LOG_LEVEL=4 # Debug logging
-DTF_LITE_DISABLE_X86_NEON=1
-DEIDSP_SIGNAL_C_FN_POINTER=1
-DEI_C_LINKAGE=1
-fno-exceptions # Turn off exceptions for WASM
-Wno-strict-aliasing
-Wno-unknown-attributes
-I${CMAKE_SOURCE_DIR}
# Set C++ standard for C++ files
set(CMAKE_CXX_STANDARD 11)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
# Set linker flags
add_link_options(
-Wl,--strip-all
-lm
# Define source files (mirroring Makefile)
set(CSOURCES
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/c/common.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/BasicMathFunctions/*.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/FastMathFunctions/*.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/*.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/*fft*.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/CommonTables/*.c
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/*bit*.c
set(CXXSOURCES
${CMAKE_SOURCE_DIR}/tflite-model/*.cpp
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/dsp/kissfft/*.cpp
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/dsp/dct/*.cpp
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/dsp/memory.cpp
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/classifier/*.cpp
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/porting/posix/*.c*
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/porting/mingw32/*.c*
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/kernels/*.cc
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/kernels/internal/*.cc
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/micro/kernels/*.cc
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/micro/*.cc
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/micro/memory_planner/*.cc
${CMAKE_SOURCE_DIR}/edge-impulse-sdk/tensorflow/lite/core/api/*.cc
set(APP_CSOURCES
${CMAKE_SOURCE_DIR}/source/main.c
# Optional CMSIS-NN sources
# option(USE_CMSIS_NN "Enable CMSIS-NN optimizations" OFF)
# if(USE_CMSIS_NN)
# add_compile_options(
# -DEI_CLASSIFIER_TFLITE_ENABLE_CMSIS_NN=1
# -D__ARM_FEATURE_DSP=1
# -D__GNUC_PYTHON__=1
# -I${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Include/
# -I${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/DSP/PrivateInclude/
# list(APPEND CSOURCES
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/ActivationFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/BasicMathFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/ConcatenationFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/ConvolutionFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/FullyConnectedFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/ReshapeFunctions/*.c
# ${CMAKE_SOURCE_DIR}/edge-impulse-sdk/CMSIS/NN/Source/SoftmaxFunctions/*.c
# endif()
# Glob source files
file(GLOB CSOURCE_FILES ${CSOURCES})
file(GLOB CXXSOURCE_FILES ${CXXSOURCES})
file(GLOB APP_CSOURCE_FILES ${APP_CSOURCES})
# Create executable
add_executable(${APPNAME}.wasm ${CSOURCE_FILES} ${CXXSOURCE_FILES} ${APP_CSOURCE_FILES})
# Link libraries (math library included via add_link_options)
target_link_libraries(${APPNAME}.wasm PRIVATE m)
Lastly, I had to make one change to the POSIX porting file to make this compatible with my WASM toolchain:
// #if EI_CLASSIFIER_USE_GPU_DELEGATES==1
clockid_t clock_id = CLOCK_MONOTONIC;
// #else
// clockid_t clock_id = CLOCK_PROCESS_CPUTIME_ID;
// #endif
Our toolchain only supports CLOCK_MONOTONIC.
- Platform: aarch64 Docker container, but targeting Raspi 5
- OS Version: Ubuntu 22.04 / Raspbian Bookworm
- Edge Impulse Version (Firmware): 1.74.30
How can I go about debugging this? My other model worked just fine and I’m confused as to why I am having issues with this specific one.
