Issue with Linux CLI Install
After following the instructions for the linux cli installation afer running the command npm install -g edge-impulse-cli
I ran into the error code:
prebuild-install WARN install EACCES: permission denied, access ‘/root/.npm’
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build’
gyp ERR! System Linux 5.8.0-59-generic
gyp ERR! command “/usr/bin/node” “/usr/bin/node-gyp” “rebuild”
gyp ERR! cwd /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
gyp ERR! node -v v10.19.0
gyp ERR! node-gyp -v v6.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2021-07-02T10_05_48_058Z-debug.log
I tried using sudo npm install -g edge-imuplse-cli
as there was a permissions error and this did not work. I then read through the faqs and used the command npm config set user root
as there was a similar error but this did not work for both the sudo and non-sudo command.
My linux version is: Ubuntu 20.04.2 LTS
Python3 version: 3.8.5
NPM version: 6.14.4
