I am currently working on deploying an Edge Impulse model within a micro-ROS node on a Linux machine
Ubuntu 22.04, which will later be deployed on a Renesas RA6M5 MCU. I have successfully tested the standalone inferencing example, where the model correctly processes image data. However, I am encountering issues with correctly filling the input buffer to pass to the classifier in my micro-ROS node setup.
I want to use the built in image processing functions provided by the C++ SDK. I have been using the following example to resize the image before sending it to run_classifier function. However I recieve a segmentation fault in the function cropImage(…). I am using the following code as example: GitHub - edgeimpulse/example-resize-image: Example of using SDK to resize images before run_classifier
- Micro-ROS Node: Deployed on a Linux machine Ubuntu 22.04, communicates with another ROS node via a micro-ROS agent.
- Hardware Target: The final deployment will be on a Renesas RA6M5 MCU.
- Video Source: The video frames are published by a ROS node, captured via OpenCV, and converted to ROS
sensor_msgs/msg/Imagemessages.
- Implemented a micro-ROS node that subscribes to video frames and attempts to convert the frame data into an input buffer for the Edge Impulse classifier.
- Used OpenCV on the ROS node to capture video, convert frames to RGB format, and publish them as
sensor_msgs/msg/Imagemessages. - Developed a callback function in the micro-ROS node to process the incoming frames and prepare the input buffer for classification.
The incoming frames should be processed correctly, and the input buffer should match the expected format and size
Always
MicroROS code:
#include <rcl/rcl.h>
#include <rclc/rclc.h>
#include <rclc/executor.h>
#include <std_msgs/msg/string.h>
#include <sensor_msgs/msg/image.h>
#include "edge-impulse-sdk/dsp/image/processing.hpp"
#include <stdint.h>
#include <stdio.h>
// Raw features
static uint8_t resized_image[EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT * 3] = {0};
// ROS publisher
rcl_publisher_t inference_publisher;
// Function to convert image data to float array for classifier
static int get_signal_data(size_t offset, size_t length, float *out_ptr);
// Forward declarations
void image_callback(const void *msgin);
void publish_classification_result(rcl_publisher_t *publisher, const char *result);
using namespace ei::image::processing;
int main(int argc, char **argv) {
// Initialize ROS 2
rcl_ret_t rc;
rcl_allocator_t allocator = rcl_get_default_allocator();
rclc_support_t support;
rcl_node_t node;
rcl_subscription_t image_subscription;
sensor_msgs__msg__Image image_message; // Declare an instance of the message type
rc = rclc_support_init(&support, argc, argv, &allocator);
rc += rclc_node_init_default(&node, "tack_classifier_node", "", &support);
// Initialize publisher
rc += rclc_publisher_init_default(
&inference_publisher,
&node,
ROSIDL_GET_MSG_TYPE_SUPPORT(std_msgs, msg, String),
"inference_stream");
// Initialize subscriber for images
rc += rclc_subscription_init_default(
&image_subscription,
&node,
ROSIDL_GET_MSG_TYPE_SUPPORT(sensor_msgs, msg, Image),
"video_frames");
// Initialize executor
rclc_executor_t executor;
rclc_executor_init(&executor, &support.context, 1, &allocator);
rclc_executor_add_subscription(
&executor,
&image_message, // Pass the instance of message type
image_callback, // Changed to function pointer
ON_NEW_DATA);
// Spin the executor (equivalent to rclpy.spin)
rclc_executor_spin(&executor);
// Clean up resources
rcl_subscription_fini(&image_subscription, &node);
rcl_publisher_fini(&inference_publisher, &node);
rclc_executor_fini(&executor);
rcl_node_fini(&node);
rclc_support_fini(&support);
return 0;
// Image callback function to process video frames
void image_callback(const void *msgin) {
EI_IMPULSE_ERROR res; // Return code from inference
printf("check 1\n");
const sensor_msgs__msg__Image *image_msg = (const sensor_msgs__msg__Image *)msgin;
// Check encoding (assuming "rgb8" format)
if (strcmp(image_msg->encoding.data, "rgb8") != 0) {
printf("Unsupported image encoding: %s\n", image_msg->encoding.data);
return;
printf("check 2\n");
// Resize the image
int res_int = ei::image::processing::resize_image_using_mode(
image_msg->data.data,
image_msg->width,
image_msg->height,
resized_image,
EI_CLASSIFIER_INPUT_WIDTH,
EI_CLASSIFIER_INPUT_HEIGHT,
3, // RGB888
EI_CLASSIFIER_RESIZE_MODE);
printf("check 3\n");
if (res_int != 0) {
printf("Error resizing image: %d\n", res);
return;
// Prepare the signal
signal_t signal = {
.get_data = &get_signal_data, // Initialize 'get_data' first
.total_length = EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE // Initialize 'total_length' second
printf("check 4\n");
ei_impulse_result_t result = {0};
// Classify image using Edge Impulse
res = run_classifier(&signal, &result, false);
printf("check 5\n");
if (res == EI_IMPULSE_OK) {
// Process results and create a classification string
char result_str[1024];
snprintf(result_str, sizeof(result_str), "Detected: %s (%.2f)", result.classification[0].label, result.classification[0].value);
// Publish the result
publish_classification_result(&inference_publisher, result_str);
else
printf("Error classifying the image\n");
printf("check 6\n");
// Callback: fill a section of the out_ptr buffer when requested
static int get_signal_data(size_t offset, size_t length, float *out_ptr) {
size_t pixel_ix = offset * 3;
size_t out_ptr_ix = 0;
while (length != 0) {
// pixels are written into the mantissa of the float
out_ptr[out_ptr_ix] = (resized_image[pixel_ix] << 16) +
(resized_image[pixel_ix + 1] << 8) +
resized_image[pixel_ix + 2];
// go to the next pixel
out_ptr_ix++;
pixel_ix += 3;
length--;
return EIDSP_OK;
// Function to publish classification result
void publish_classification_result(rcl_publisher_t *publisher, const char *result) {
std_msgs__msg__String msg;
size_t result_length = strlen(result);
msg.data.data = (char *)malloc(result_length + 1); // Allocate memory for the string
if (msg.data.data == NULL) {
printf("Failed to allocate memory for message data\n");
return;
strcpy(msg.data.data, result); // Copy the string into the allocated memory
msg.data.size = result_length;
msg.data.capacity = result_length + 1;
rcl_publish(publisher, &msg, NULL);
// Free allocated memory after publishing
free(msg.data.data);
**Publisher Code: **
import rclpy
from rclpy.node import Node
import cv2
from cv_bridge import CvBridge
from sensor_msgs.msg import Image
class VideoPublisher(Node):
def __init__(self):
super().__init__('video_publisher')
# Declare the video path parameter
self.declare_parameter('video_path', '')
# Wait until a valid video path is provided
self.video_path = self.get_parameter('video_path').get_parameter_value().string_value
while not self.video_path:
self.get_logger().info('Waiting for video path to be provided...')
rclpy.spin_once(self)
# Initialize the video capture with the provided path
self.cap = cv2.VideoCapture(self.video_path)
if not self.cap.isOpened():
self.get_logger().error(f"Could not open video file: {self.video_path}")
rclpy.shutdown()
return
# Create a publisher
self.publisher_ = self.create_publisher(Image, 'video_frames', 10)
# Initialize the CvBridge
self.bridge = CvBridge()
# Set the timer period for 30 FPS
timer_period = 1.0 / 30.0 # 30 FPS
self.timer = self.create_timer(timer_period, self.timer_callback)
def timer_callback(self):
# Capture a frame from the video
ret, frame = self.cap.read()
if not ret:
self.get_logger().info('Video stream ended.')
self.cap.release()
rclpy.shutdown()
return
# Convert the OpenCV BGR image to RGB
rgb_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
self.get_logger().info('Converted to RGB')
# Display the frame that is being published
cv2.imshow("Published Frame", rgb_frame)
cv2.waitKey(1) # Allows the image to be displayed properly
# Convert the RGB image to a ROS Image message
image_message = self.bridge.cv2_to_imgmsg(rgb_frame, encoding='rgb8')
# Publish the Image message
self.publisher_.publish(image_message)
self.get_logger().info('Publishing video frame')
def main(args=None):
rclpy.init(args=args)
video_publisher = VideoPublisher()
rclpy.spin(video_publisher)
video_publisher.destroy_node()
rclpy.shutdown()
# Close OpenCV windows
cv2.destroyAllWindows()
if __name__ == '__main__':
main()
- How can I correctly convert and format the incoming image data from the
sensor_msgs/msg/Imageto match the expected input buffer format for the Edge Impulse classifier? - Is there a more efficient way to handle RGB image data and convert it to the required format for inference?
