Issue with classifier on Nicla Sense ME
Hello, so i have created a model and i am trying to deploy it to Nicla Sense ME. I created the arduino library, added it to the Arduino IDE, and chose the example for Nicla Sense ME called nicla_sense_fusion. The only things i changed is the label names to match my project’s names and added some prints.
After deploying the script to nicla, this is the output i’m getting.
Edge Impulse Sensor Fusion Inference
Sampling...
1920�
Basically nicla stops running at this line. (I added the print for 1920 cause i was curious about the size of the array)
So i have several questions. Does anyone have any idea why that is? Is my Nicla running out of memmory?. Also do i need to use all the sensors even though my classifier doesn’t use all of them? What is the use of this buffer? I have added the whole script for reference below, if you need more details let me know.
/* Edge Impulse ingestion SDK
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <LABNICLA_inferencing.h>
#include "Arduino_BHY2.h" //Click here to get the library: http://librarymanager/All#Arduino_BHY2
/** Struct to link sensor axis name to sensor value function */
typedef struct{
    const char *name;
    float (*get_value)(void);
}eiSensors;
#define CONVERT_G_TO_MS2    9.80665f
/** Number sensor axes used */
#define NICLA_N_SENSORS     17
static const bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
SensorXYZ accel(SENSOR_ID_ACC);
SensorXYZ gyro(SENSOR_ID_GYRO);
SensorOrientation ori(SENSOR_ID_ORI);
SensorQuaternion rotation(SENSOR_ID_RV);
Sensor temp(SENSOR_ID_TEMP);
Sensor baro(SENSOR_ID_BARO);
Sensor hum(SENSOR_ID_HUM);
Sensor gas(SENSOR_ID_GAS);
static bool ei_connect_fusion_list(const char *input_list);
static float get_accX(void){return (accel.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_accY(void){return (accel.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_accZ(void){return (accel.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrX(void){return (gyro.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrY(void){return (gyro.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrZ(void){return (gyro.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_oriHeading(void){return ori.heading();}
static float get_oriPitch(void){return ori.pitch();}
static float get_oriRoll(void){return ori.roll();}
static float get_rotX(void){return rotation.x();}
static float get_rotY(void){return rotation.y();}
static float get_rotZ(void){return rotation.z();}
static float get_rotW(void){return rotation.w();}
static float get_temperature(void){return temp.value();}
static float get_barrometric_pressure(void){return baro.value();}
static float get_humidity(void){return hum.value();}
static float get_gas(void){return gas.value();}
static int8_t fusion_sensors[NICLA_N_SENSORS];
static int fusion_ix = 0;
/** Used sensors value function connected to label name */
eiSensors nicla_sensors[] =
    "accX", &get_accX,
    "accY", &get_accY,
    "accZ", &get_accZ,
    "gyroX", &get_gyrX,
    "gyroY", &get_gyrY,
    "gyroZ", &get_gyrZ,
    "heading", &get_oriHeading,
    "pitch", &get_oriPitch,
    "roll", &get_oriRoll,
    "rotX", &get_rotX,
    "rotY", &get_rotY,
    "rotZ", &get_rotZ,
    "rotW", &get_rotW,
    "temperature", &get_temperature,
    "barometer", &get_barrometric_pressure,
    "humidity", &get_humidity,
    "gas", &get_gas,
void setup()
    /* Init serial */
    Serial.begin(115200);
    while (!Serial);
    Serial.println("Edge Impulse Sensor Fusion Inference\r\n");
    /* Connect used sensors */
    if(ei_connect_fusion_list(EI_CLASSIFIER_FUSION_AXES_STRING) == false) {
        ei_printf("ERR: Errors in sensor list detected\r\n");
        return;
    /* Init & start sensors */
    BHY2.begin(NICLA_I2C);
    accel.begin();
    gyro.begin();
    ori.begin();
    rotation.begin();
    temp.begin();
    baro.begin();
    hum.begin();
    gas.begin();
void loop()
    ei_printf("\nStarting inferencing in 2 seconds...\r\n");
    delay(2000);
    if (EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME != fusion_ix) {
        ei_printf("ERR: Nicla sensors don't match the sensors required in the model\r\n"
        "Following sensors are required: %s\r\n", EI_CLASSIFIER_FUSION_AXES_STRING);
        return;
    ei_printf("Sampling...\r\n");
    Serial.print(EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("Allocated Buffer\r\n");
    for (size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME) {
        ei_printf("For loop\r\n");
        int64_t next_tick = (int64_t)micros() + ((int64_t)EI_CLASSIFIER_INTERVAL_MS * 1000);
        // Update function should be continuously polled
        BHY2.update();
        for(int i = 0; i < fusion_ix; i++) {
            buffer[ix + i] = nicla_sensors[fusion_sensors[i]].get_value();
        int64_t wait_time = next_tick - (int64_t)micros();
        if(wait_time > 0) {
            delayMicroseconds(wait_time);
    signal_t signal;
    if (err != 0) {
        ei_printf("ERR:(%d)\r\n", err);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.):\r\n",
        ei_printf("%s: %.5f\r\n", result.classification[ix].label, result.classification[ix].value);
    ei_printf("    anomaly score: %.3f\r\n", result.anomaly);
#endif
#if !defined(EI_CLASSIFIER_SENSOR) || (EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_FUSION && EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_ACCELEROMETER)
#endif
 * @brief Go through nicla sensor list to find matching axis name
 * @param axis_name
 * @return int8_t index in nicla sensor list, -1 if axis name is not found
static int8_t ei_find_axis(char *axis_name)
    int ix;
    for(ix = 0; ix < NICLA_N_SENSORS; ix++) {
        if(strstr(axis_name, nicla_sensors[ix].name)) {
            return ix;
    return -1;
 * @brief Check if requested input list is valid sensor fusion, create sensor buffer
 * @param[in]  input_list      Axes list to sample (ie. "accX + gyrY + magZ")
 * @retval  false if invalid sensor_list
    char *buff;
    bool is_fusion = false;
    /* Copy const string in heap mem */
    char *input_string = (char *)ei_malloc(strlen(input_list) + 1);
    if (input_string == NULL) {
        return false;
    memset(input_string, 0, strlen(input_list) + 1);
    strncpy(input_string, input_list, strlen(input_list));
    /* Clear fusion sensor list */
    memset(fusion_sensors, 0, NICLA_N_SENSORS);
    fusion_ix = 0;
    buff = strtok(input_string, "+");
    while (buff != NULL) { /* Run through buffer */
        int8_t found_axis = 0;
        is_fusion = false;
        found_axis = ei_find_axis(buff);
        if(found_axis >= 0) {
            if(fusion_ix < NICLA_N_SENSORS) {
                fusion_sensors[fusion_ix++] = found_axis;
            is_fusion = true;
        buff = strtok(NULL, "+ ");
    ei_free(input_string);
    return is_fusion;
Hello @apfotopoulos
Probably. If you don’t need all your sensors, indeed, just you the ones you need.
This buffer is used to store the raw data.
@luisomoreau do you mean to
a) Collect with less channels
b) collect a smaller number of trials
c) collect smaller trials (less seconds)
or
d) remove from the deployment arduino file the channels that are not used
also
e) the EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE gets a value of 1920. This number does look like the 1920 pixels in the HD panel. Are you sure this number is also applicable for nicla sense ?
I have same issue
I process only accelerometer sensors (3) but same “?” in serial monitor on Nicla sense
project in Edge impulse is “Fan status”
thank you
