I need to interface my Nicla Voice to a suitable external device such as an opto-coupler to allow a relay to signal to another device. What is the most effective method of achieving this aim. I realise there are pins available but they do not have the capacity to switch an opto-coupler directly.
Any helpful suggestions appreciated. Project ID:
What is max GPIO output current (amps) for the Nicla Voice (NV)? (I found the output is configurable between 1.8V and 3.3V but could not find a GPIO output amps spec.)
If the optocoupler needs more drive current to turn it on than the NV can output, then put an open collector transistor between the NV and the opto. A general x-istor will take a few 10s of microamps to turn on the x-istor thru the Base pin.
Here is a simple 2N2222 x-istor schematic that takes 1 mA to turn on. Surely, the NV can output 1 mA, right.
ĂŚ have sourced an SSR unit with 3mA Input current and 230V o/p.
If it was difficult to get a low current SSR I was thinking of using a number of the digital o/p’s and turning all of them on at the same time ?
This should give more flexibility!!
