Int8 model training data resolution
Hi, I was wondering if I am going to deploy my model as an optimized 8int model, should i use my original data that is 12bit in resolution or trim my data to be 8 bit for training and testing?
I like to use Artificial Neural Network for an electronic nose. My sensors are 12 bit in resolution and my device is esp32S3. For some reason, when i deploy a float32 model with esp-idf, it doesnt work. So i can only use the int8 model, should my data be trimmed from 12bit to 8bit for training and testing? How will the resolution of data affect model inference?
  • Platform: ESP32S3
  • Build Environment Details: ESP-IDF
Hi @vdhorstnigel
No keep it at 12bit upload, and on deploy enable int8.
Resolution is typically worth the trade off in size 2-8%, If you’re seeing issues with float32 deployment on ESP-IDF, that’s common due to limited floating-point support on some ESP32 variants. Using the quantized model is the right approach for this platform.
