Question:
Today post-quantisation is performed, and full integer quantisation for the int8 model. Correct?
For full integer quantisation, you need a representative dataset. How is this dataset created in the back? Is it the complete valdation set?
By looking into the code ( Exporting block to edit locally…), more specifically in conversion.py theres is representative_dataset_generator(validation_dataset). It is correct that this takes to complete the validation dataset.
I ask this because I had recently a drop in accuracy for the int8 after changing the size of the validation set. My hypothesis is: that the size of the new validation was no longer sufficient for the representative dataset.
Joeri
