With multiple attempted deployments from Edge Impulse, I keep getting a build loop ultimately failing due to a dirty build.ninja file. I’ve checked system datetime, pristine builds, restarting my computer, etc. Project ID:
Various, but at the current moment is project 353426. Context/Use case:
The build output is as follows, from the Wrapper sample using a custom replication of the FOMO sample:
[143/158] No update step for 'edge_impulse_project'
[144/158] Performing patch step for 'edge_impulse_project'
[145/158] Performing configure step for 'edge_impulse_project'
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build/edge_impulse/src/edge_impulse_project-build
[145/158] Performing build step for 'edge_impulse_project'
[0/1] Re-running CMake...
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
…about 95 more of these…
-- Configuring done
-- Generating done
ninja: error: manifest 'build.ninja' still dirty after 100 tries
FAILED: edge_impulse/src/edge_impulse_project-stamp/edge_impulse_project-build edge_impulse/src/edge_impulse_project-build/libedge_impulse.a
cd /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build/edge_impulse/src/edge_impulse_project-build && /opt/nordic/ncs/toolchains/20d68df7e5/Cellar/cmake/3.20.5/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/20d68df7e5/bin/cmake --build /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build
If anyone has seen this before or has a guess of how to fix it, that’d be greatly appreciated.
They are in the build console of VS Code, on my local computer.
Building with nRF for an nRF52840dk, flashing is not an issue as building hasn’t succeeded yet.
I have set the target the same on Edge Impulse.
The weird part is this issue is only appearing if I attempt to build/deploy models (via the Edge Impulse Wrapper sample provided with nRF) that are computer vision based - the Continuous Motion model works just fine. Thanks for any help.
Tried that but it didn’t seem to work. We’re not sure, it’s not a reliable issue.
We’ve started getting this error:
CMake Warning (dev) at /opt/homebrew/Cellar/cmake/3.28.3/share/cmake/Modules/ExternalProject.cmake:3195 (message):
The DOWNLOAD_EXTRACT_TIMESTAMP option was not given and policy CMP0135 is
not set. The policy's OLD behavior will be used. When using a URL
download, the timestamps of extracted files should preferably be that of
the time of extraction, otherwise code that depends on the extracted
contents might not be rebuilt if the URL changes. The OLD behavior
preserves the timestamps from the archive instead, but this is usually not
what you want. Update your project to the NEW behavior or specify the
DOWNLOAD_EXTRACT_TIMESTAMP option with a value of true to avoid this
robustness issue.
Wondering if it could possibly be a cause, but our CMakeLists.txt also specifies a remote file to download so that could be where that comes from instead.
