I’ve trained a ML model which works perfectly on vibration continuous mode. I want to integrate bluetooth so I can send the inference results to the MIT app inventor.
I’ve tried everything, following other examples (which samples every 2 second) etc… to include bluetooth, but I can’t get it to work properly.
I’ve attached the clean code of the inferencing, does anyone know how to allow your device to connect to BLE whilst running in this continuous mode?
/* Edge Impulse ingestion SDK
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <AnomolyDetect_inferencing.h>
#include <LSM6DS3.h> //Click here to get the library: http://librarymanager/All#Arduino_LSM9DS1
#include <ArduinoBLE.h>
#define CONVERT_G_TO_MS2    9.80665f
#define MAX_ACCEPTED_RANGE  2.0f        // starting 03/2022, models are generated setting range to +-2, but this example use Arudino library which set range to +-4g. If you are using an older model, ignore this value and use 4.0f instead
 ** NOTE: If you run into TFLite arena allocation issue.
 ** This may be due to may dynamic memory fragmentation.
 ** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
 ** if it doesn't exist) and copy this file to
 ** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
 ** See
 ** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
 ** to find where Arduino installs cores on your machine.
 ** If the problem persists then there's not enough memory for this model and application.
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
static float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
LSM6DS3 myIMU(I2C_MODE, 0x6A);
// Service UUID
BLEService bleService("19B10000-E8F2-537E-4F6C-D104768A1214");
// Characteristic UUID
BLEStringCharacteristic predictionChar("a5e93786-602d-4769-932f-fc62699df97a", BLERead | BLEWrite | BLENotify, 100 );
BLEFloatCharacteristic offcount("be574fe6-9bdc-4f88-abde-4393ec367590", BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic speed3count("3daa9df0-5ca4-4289-ab23-7c7be9205af6", BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic speed7count("fae59b4b-ef27-437b-8d2c-35ca21218dc8", BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic uncertaincount("609a46e0-17b8-4974-86f7-e9f33569a08f", BLERead | BLEWrite | BLENotify);
BLEFloatCharacteristic anomolycount("de4fd609-4981-4c25-8c60-c6cb0640f2d5", BLERead | BLEWrite | BLENotify);
/* Forward declaration */
void run_inference_background();
void setup()
    Serial.begin(115200);
    delay(200);
    // Accelerometer Setup
    myIMU.settings.accelRange = 4;      //Max G force readable.  Can be: 2, 4, 8, 16
    myIMU.settings.accelSampleRate = 1666;  //Hz.  Can be: 13, 26, 52, 104, 208, 416, 833, 1666, 3332, 6664, 13330
    myIMU.settings.accelBandWidth = 400;  //Hz.  Can be: 50, 100, 200, 400;
    // BLE Setup
    //Set local name and service UUID
    BLE.setDeviceName("XIAOB");
    BLE.setLocalName("XIAO");
    BLE.setAdvertisedService(bleService);
    //add characteristic to the service
    bleService.addCharacteristic(predictionChar);
    bleService.addCharacteristic(offcount);
    bleService.addCharacteristic(speed3count);
    bleService.addCharacteristic(speed7count);
    bleService.addCharacteristic(uncertaincount);
    bleService.addCharacteristic(anomolycount);
    //add service
    BLE.addService(bleService);
    //set initial values for the characteristics
    predictionChar.writeValue("None");
    offcount.writeValue(0);
    speed3count.writeValue(0);
    speed7count.writeValue(0);
    uncertaincount.writeValue(0);
    anomolycount.writeValue(0);
    //start advertising
    BLE.advertise();
    while (!Serial);
    if (!myIMU.begin()) {
        ei_printf("Failed to initialize IMU!\r\n");
    else {
        ei_printf("IMU initialized\r\n");
        return;
    inference_thread.start(mbed::callback(&run_inference_background));
 * @brief Return the sign of the number
 * @param number
 * @return int 1 if positive (or 0) -1 if negative
float ei_get_sign(float number) {
    return (number >= 0.0) ? 1.0 : -1.0;
 * @brief      Run inferencing in the background.
  // wait until we have a full buffer
  delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
  // This is a structure that smoothens the output result
  // With the default settings 70% of readings should be the same before classifying.
  ei_classifier_smooth_t smooth;
  ei_classifier_smooth_init(&smooth, 10 /* no. of readings */, 7 /* min. readings the same */, 0.8 /* min. confidence */, 0.3 /* max anomaly */);
  while (1) {
      // copy the buffer
      memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
      signal_t signal;
      int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
      if (err != 0) {
          return;
      // Run the classifier
      if (err != EI_IMPULSE_OK) {
          return;
      // print the predictions
      ei_printf("Predictions ");
      ei_printf(": ");
      // ei_classifier_smooth_update yields the predicted label
      const char *prediction = ei_classifier_smooth_update(&smooth, &result);
      ei_printf("%s ", prediction);
      // print the cumulative results
      ei_printf(" [ ");
      for (size_t ix = 0; ix < smooth.count_size; ix++) {
          ei_printf("%u", smooth.count[ix]);
          if (ix != smooth.count_size + 1) {
              ei_printf(", ");
          else {
            ei_printf(" ");
      ei_printf("]\n");
      delay(run_inference_every_ms);
  ei_classifier_smooth_free(&smooth);
* @param[in]  debug  Get debug info if true
void loop()
  //BLEDevice central = BLE.central();
  while (1) {
      // roll the buffer -3 points so we can overwrite the last one
      numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
      // read to the end of the buffer
      buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3]=myIMU.readFloatAccelX();
      buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2]=myIMU.readFloatAccelY();
      buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1]=myIMU.readFloatAccelZ();
      for (int i = 0; i < 3; i++) {
          if (fabs(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) > MAX_ACCEPTED_RANGE) {
              buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i] = ei_get_sign(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) * MAX_ACCEPTED_RANGE;
      //buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] *= CONVERT_G_TO_MS2;
      //buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] *= CONVERT_G_TO_MS2;
      //buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] *= CONVERT_G_TO_MS2;
      // and wait for next tick
      uint64_t time_to_wait = next_tick - micros();
      delay((int)floor((float)time_to_wait / 1000.0f));
      delayMicroseconds(time_to_wait % 1000);
Second Problem:
This is the code for the non- contineous inferacing. I’m able to connect the xiao via bluetooth, however, the inferacing results do not print out. I’m not updating any characteristics, I just want to see if bluetooth and printing results can work together. This code (for debugging purposes) runs until Serial.println(“3”) in void_loop and does not reach to Serialprintln(“4”).
 ** See
// Service UUID
void setup()
    delay(2000);
    while (!Serial);
    if (!BLE.begin()) {   // initialize BLE
      Serial.println("starting BLE failed!");
      while (1);
        // BLE Setup
    //add service
    //start advertising
    BLE.advertise();
    else {
        return;
 * @param number
void loop()
    if (central.discoverAttributes()) {
      Serial.print("Connected to central: ");
      Serial.println(central.address());
      while (central.connected()) {
        ei_printf("\nStarting inferencing in 1 seconds...\n");
        delay(1000);
        ei_printf("Sampling...\n");
            Serial.println("1");
            buffer[ix + 0] = myIMU.readFloatAccelX();
            buffer[ix + 1] = myIMU.readFloatAccelY();
            buffer[ix + 2] = myIMU.readFloatAccelZ();
            Serial.println("2");
            //IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
                if (fabs(buffer[ix + i]) > MAX_ACCEPTED_RANGE) {
                    buffer[ix + i] = ei_get_sign(buffer[ix + i]) * MAX_ACCEPTED_RANGE;
            Serial.println("3");
            //buffer[ix + 0] *= CONVERT_G_TO_MS2;
            //buffer[ix + 1] *= CONVERT_G_TO_MS2;
            //buffer[ix + 2] *= CONVERT_G_TO_MS2;
            Serial.println("4");
        Serial.println("5");
        signal_t signal;
        if (err != 0) {
            return;
            return;
        ei_printf(": \n");
            ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
        Serial.println("6");
    #endif
Thanks.
