Inference on Nicla Sense ME via Bluetooth
Looking for example. How can I send inference result from Nicla Sense ME over bluetooth? I tried following code but getting mbed error on serial.
#include <ArduinoBLE.h>        //Click here to get the library: http://librarymanager/All#ArduinoBLE
#define  DEBUG_FLAG 0
#include <Wire.h>
#include <my_fitness_inferencing.h>
#include "Arduino_BHY2.h" //Click here to get the library: http://librarymanager/All#Arduino_BHY2
BLEService inferenceService("2d0a0000-e0f7-5fc8-b50f-05e267afeb67");
BLEStringCharacteristic inferenceCharacteristic("2d0a0001-e0f7-5fc8-b50f-05e267afeb67", BLERead | BLENotify, 56);
/** Struct to link sensor axis name to sensor value function */
typedef struct{
    const char *name;
    float (*get_value)(void);
}eiSensors;
#define CONVERT_G_TO_MS2    9.80665f
/** Number sensor axes used */
#define NICLA_N_SENSORS     17
static const bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
SensorXYZ accel(SENSOR_ID_ACC);
SensorXYZ gyro(SENSOR_ID_GYRO);
SensorOrientation ori(SENSOR_ID_ORI);
SensorQuaternion rotation(SENSOR_ID_RV);
Sensor temp(SENSOR_ID_TEMP);
Sensor baro(SENSOR_ID_BARO);
Sensor hum(SENSOR_ID_HUM);
Sensor gas(SENSOR_ID_GAS);
static bool ei_connect_fusion_list(const char *input_list);
static float get_accX(void){return (accel.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_accY(void){return (accel.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_accZ(void){return (accel.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrX(void){return (gyro.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrY(void){return (gyro.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_gyrZ(void){return (gyro.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2;}
static float get_oriHeading(void){return ori.heading();}
static float get_oriPitch(void){return ori.pitch();}
static float get_oriRoll(void){return ori.roll();}
static float get_rotX(void){return rotation.x();}
static float get_rotY(void){return rotation.y();}
static float get_rotZ(void){return rotation.z();}
static float get_rotW(void){return rotation.w();}
static float get_temperature(void){return temp.value();}
static float get_barrometric_pressure(void){return baro.value();}
static float get_humidity(void){return hum.value();}
static float get_gas(void){return gas.value();}
static int8_t fusion_sensors[NICLA_N_SENSORS];
static int fusion_ix = 0;
/** Used sensors value function connected to label name */
eiSensors nicla_sensors[] =
    "accX", &get_accX,
    "accY", &get_accY,
    "accZ", &get_accZ,
    "gyrX", &get_gyrX,
    "gyrY", &get_gyrY,
    "gyrZ", &get_gyrZ,
    "heading", &get_oriHeading,
    "pitch", &get_oriPitch,
    "roll", &get_oriRoll,
    "rotX", &get_rotX,
    "rotY", &get_rotY,
    "rotZ", &get_rotZ,
    "rotW", &get_rotW,
    "temperature", &get_temperature,
    "barometer", &get_barrometric_pressure,
    "humidity", &get_humidity,
    "gas", &get_gas,
void setup()
    /* Init serial */
    Serial.begin(115200);
    while (!Serial);
    Serial.println("Edge Impulse Sensor Fusion Inference\r\n");
    /* Connect used sensors */
    if(ei_connect_fusion_list(EI_CLASSIFIER_FUSION_AXES_STRING) == false) {
        ei_printf("ERR: Errors in sensor list detected\r\n");
        return;
    /* Init & start sensors */
   BHY2.begin(NICLA_I2C);
    accel.begin();
    gyro.begin();
    ori.begin();
    rotation.begin();
    temp.begin();
    baro.begin();
    hum.begin();
    gas.begin();
       if (!BLE.begin()) {   // initialize BLE
      Serial.println("starting BLE failed!");
      while (1);
    BLE.setLocalName("Tim-Nicla");  // Set device name
    //Set the minimum and maximum desired connection intervals in units of 1.25 ms.
    //Bluetooth LE desired connection Interval 160ms - 200ms. Central has the final word!
    BLE.setConnectionInterval(160, 200);
    BLE.setAdvertisedService(inferenceService); // Advertise service
    inferenceService.addCharacteristic(inferenceCharacteristic); // Add characteristic to service
    BLE.addService(inferenceService); // Add service
    inferenceCharacteristic.writeValue("inference"); // Set first value string
    //Set the advertising interval in units of 0.625 ms
    //Bluetooth LE advertising interval around 50ms
    BLE.setAdvertisingInterval(80);
    BLE.advertise();  // Start advertising
    #if (DEBUG_FLAG==1)
        Serial.print("Peripheral device MAC: ");
        Serial.println(BLE.address());
        Serial.println("Waiting for connections...");
    #endif
void loop()
      BLEDevice central = BLE.central();
      String inferenceResult = "";
    ei_printf("\nStarting inferencing in 2 seconds...\r\n");
    delay(2000);
    if (EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME != fusion_ix) {
        ei_printf("ERR: Nicla sensors don't match the sensors required in the model\r\n"
        "Following sensors are required: %s\r\n", EI_CLASSIFIER_FUSION_AXES_STRING);
        return;
    ei_printf("Sampling...\r\n");
    for (size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME) {
        int64_t next_tick = (int64_t)micros() + ((int64_t)EI_CLASSIFIER_INTERVAL_MS * 1000);
        // Update function should be continuously polled
        BHY2.update();
        for(int i = 0; i < fusion_ix; i++) {
            buffer[ix + i] = nicla_sensors[fusion_sensors[i]].get_value();
        int64_t wait_time = next_tick - (int64_t)micros();
        if(wait_time > 0) {
            delayMicroseconds(wait_time);
    signal_t signal;
    if (err != 0) {
        ei_printf("ERR:(%d)\r\n", err);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.):\r\n",
        ei_printf("%s: %.5f\r\n", result.classification[ix].label, result.classification[ix].value);
        if(result.classification[ix].value >0.7 && inferenceResult != result.classification[ix].label){
              inferenceResult = result.classification[ix].label;
              sendInferenceOverBLE(inferenceResult);
    ei_printf("    anomaly score: %.3f\r\n", result.anomaly);
#endif
#if !defined(EI_CLASSIFIER_SENSOR) || (EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_FUSION && EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_ACCELEROMETER)
#endif
static int8_t ei_find_axis(char *axis_name)
    int ix;
    for(ix = 0; ix < NICLA_N_SENSORS; ix++) {
        if(strstr(axis_name, nicla_sensors[ix].name)) {
            return ix;
    return -1;
    char *buff;
    bool is_fusion = false;
    /* Copy const string in heap mem */
    char *input_string = (char *)ei_malloc(strlen(input_list) + 1);
    if (input_string == NULL) {
        return false;
    memset(input_string, 0, strlen(input_list) + 1);
    strncpy(input_string, input_list, strlen(input_list));
    /* Clear fusion sensor list */
    memset(fusion_sensors, 0, NICLA_N_SENSORS);
    fusion_ix = 0;
    buff = strtok(input_string, "+");
    while (buff != NULL) { /* Run through buffer */
        int8_t found_axis = 0;
        is_fusion = false;
        found_axis = ei_find_axis(buff);
        if(found_axis >= 0) {
            if(fusion_ix < NICLA_N_SENSORS) {
                fusion_sensors[fusion_ix++] = found_axis;
            is_fusion = true;
        buff = strtok(NULL, "+ ");
    ei_free(input_string);
    return is_fusion;
void sendInferenceOverBLE(String inferenceResult) {
#if (DEBUG_FLAG==1)
     Serial.println("Sending inference result over BLE..."); // print it to serial consle
#endif
     inferenceCharacteristic.writeValue(inferenceResult); // Write value
following is the error
++ MbedOS Error Info ++
Error Status: 0x80FF0144 Code: 324 Module: 255
Error Message: Assertion failed: _stack_buffer != NULL
File: NRFCordioHCIDriver.cpp+186
Error Value: 0x0
Current Thread: main Id: 0x20004B44 Entry: 0x22FBB StackSize: 0xC00 StackMem: 0x20003F20 SP: 0x20004A04
For more info, visit: mbedos-error
– MbedOS Error Info –
I did also updated files from lib_mbed_custom_built – Google Drive but it does not work.
Hi @timothy.malche,
I don’t have much experience with BLE or the Nicla Sense ME. Have you been able to get any of the other basic BLE examples to work?
This error _stack_buffer != NULL makes me think that your RAM is full. Not sure it offers any solution, but it looks like others are running into similar issues with this board: Nicla Sense ME Running out of memory
@timothy.malche As Shawn wrote, it is probably a memory error.
I myself did get same or similar errors when using the Arduino IDE.
I was yesterday able to run inference and BLE on Nicla Sense ME by these steps:
  • moving to platformio instead of Arduino IDE,
  • changing the buffer size to 64 (from 1024 if I remember correctly) at the line #define WORK_BUFFER_SIZE 64 in the file BoschSensortec.h
Hi @shawn_edgeimpulse , @ThomasVikstrom thanks for pointing it out. I am able to run the code without any changes (without changing the buffer size) using VS Code and PlatformIO extension.
Hi @shawn_edgeimpulse @ThomasVikstrom the inferencing was running fine after I uploaded using PIO extension. But after few iteration the board becoms unstable giving following error:
Error Status: 0x80010133 Code: 307 Module: 1
Error Message: Mutex: 0x2000EF28, Parameter error
Error Value: 0x2000EF28
Current Thread: main Id: 0x2000403C Entry: 0x22FAB StackSize: 0xC00 StackMem: 0x20003418 SP: 0x2000FF44
For more info, visit: https://mbed.com/s/error?error=0x80010133&tgt=NICLA
-- MbedOS Error Info --
I also changed the WORK_BUFFER_SIZE from 2048 to 1024 as well as later to 64 but same error persists.
