I am trying to simulate different models for STM32 on proteus but getting the same wrong classification for all models (al giving an output of -5 for any label). Live classification gives correct results. Below is a sample output
@ookosoft Could this be an error with printing floats? If you do a normal printf of e.g. 0.35f does it print correctly?
Hello @ookosoft,
Could you share your the model_metadata.h file so I can have a look please?
And do you mind if I join your project to run the Live Classification?
/* Generated by Edge Impulse
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the “Software”), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
#ifndef EI_CLASSIFIER_MODEL_METADATA_H
#define EI_CLASSIFIER_MODEL_METADATA_H
#include <stdint.h>
#define EI_CLASSIFIER_NONE 255
#define EI_CLASSIFIER_UTENSOR 1
#define EI_CLASSIFIER_TFLITE 2
#define EI_CLASSIFIER_CUBEAI 3
#define EI_CLASSIFIER_TFLITE_FULL 4
#define EI_CLASSIFIER_TENSAIFLOW 5
#define EI_CLASSIFIER_TENSORRT 6
#define EI_CLASSIFIER_SENSOR_UNKNOWN -1
#define EI_CLASSIFIER_SENSOR_MICROPHONE 1
#define EI_CLASSIFIER_SENSOR_ACCELEROMETER 2
#define EI_CLASSIFIER_SENSOR_CAMERA 3
// These must match the enum values in TensorFlow Lite’s “TfLiteType”
#define EI_CLASSIFIER_DATATYPE_FLOAT32 1
#define EI_CLASSIFIER_DATATYPE_INT8 9
#define EI_CLASSIFIER_PROJECT_ID 27622
#define EI_CLASSIFIER_PROJECT_OWNER “SAMSON OTIENO OOKO”
#define EI_CLASSIFIER_PROJECT_NAME “Edge AI for COPD”
#define EI_CLASSIFIER_PROJECT_DEPLOY_VERSION 2
#define EI_CLASSIFIER_NN_INPUT_FRAME_SIZE 56
#define EI_CLASSIFIER_RAW_SAMPLE_COUNT 500
#define EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME 8
#define EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE (EI_CLASSIFIER_RAW_SAMPLE_COUNT * EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME)
#define EI_CLASSIFIER_INPUT_WIDTH 0
#define EI_CLASSIFIER_INPUT_HEIGHT 0
#define EI_CLASSIFIER_INTERVAL_MS 2
#define EI_CLASSIFIER_LABEL_COUNT 2
#define EI_CLASSIFIER_HAS_ANOMALY 0
#define EI_CLASSIFIER_FREQUENCY 500
#define EI_CLASSIFIER_USE_QUANTIZED_DSP_BLOCK 0
#define EI_CLASSIFIER_OBJECT_DETECTION 0
#define EI_CLASSIFIER_TFLITE_ARENA_SIZE 3692
#define EI_CLASSIFIER_TFLITE_INPUT_DATATYPE EI_CLASSIFIER_DATATYPE_INT8
#define EI_CLASSIFIER_TFLITE_INPUT_QUANTIZED 1
#define EI_CLASSIFIER_TFLITE_INPUT_SCALE 0.0363069511950016
#define EI_CLASSIFIER_TFLITE_INPUT_ZEROPOINT -45
#define EI_CLASSIFIER_TFLITE_OUTPUT_DATATYPE EI_CLASSIFIER_DATATYPE_INT8
#define EI_CLASSIFIER_TFLITE_OUTPUT_QUANTIZED 1
#define EI_CLASSIFIER_TFLITE_OUTPUT_SCALE 0.00390625
#define EI_CLASSIFIER_TFLITE_OUTPUT_ZEROPOINT -128
#define EI_CLASSIFIER_INFERENCING_ENGINE EI_CLASSIFIER_TFLITE
#define EI_CLASSIFIER_COMPILED 1
#define EI_CLASSIFIER_HAS_TFLITE_OPS_RESOLVER 1
#define EI_CLASSIFIER_SENSOR EI_CLASSIFIER_SENSOR_UNKNOWN
#define EI_CLASSIFIER_SLICE_SIZE (EI_CLASSIFIER_RAW_SAMPLE_COUNT / EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)
#ifndef EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW
#define EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW 4
#endif // EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW
#if EI_CLASSIFIER_INFERENCING_ENGINE == EI_CLASSIFIER_TFLITE && EI_CLASSIFIER_USE_FULL_TFLITE == 1
#undef EI_CLASSIFIER_INFERENCING_ENGINE
#undef EI_CLASSIFIER_HAS_TFLITE_OPS_RESOLVER
#define EI_CLASSIFIER_INFERENCING_ENGINE EI_CLASSIFIER_TFLITE_FULL
#define EI_CLASSIFIER_HAS_TFLITE_OPS_RESOLVER 0
#if EI_CLASSIFIER_COMPILED == 1
#error “Cannot use full TensorFlow Lite with EON”
#endif
#endif // EI_CLASSIFIER_INFERENCING_ENGINE == EI_CLASSIFIER_TFLITE && EI_CLASSIFIER_USE_FULL_TFLITE == 1
const char* ei_classifier_inferencing_categories[] = { “COPD”, “Healthy” };
typedef struct {
uint16_t implementation_version;
int axes;
float scale_axes;
bool average;
bool minimum;
bool maximum;
bool rms;
bool stdev;
bool skewness;
bool kurtosis;
} ei_dsp_config_flatten_t;
typedef struct {
int axes;
const char * channels;
} ei_dsp_config_image_t;
typedef struct {
int axes;
int num_cepstral;
float frame_length;
float frame_stride;
int num_filters;
int fft_length;
int win_size;
int low_frequency;
int high_frequency;
float pre_cof;
int pre_shift;
} ei_dsp_config_mfcc_t;
typedef struct {
int axes;
float frame_length;
float frame_stride;
int num_filters;
int fft_length;
int low_frequency;
int high_frequency;
int win_size;
} ei_dsp_config_mfe_t;
typedef struct {
int axes;
float scale_axes;
} ei_dsp_config_raw_t;
typedef struct {
int axes;
float scale_axes;
const char * filter_type;
float filter_cutoff;
int filter_order;
int fft_length;
int spectral_peaks_count;
float spectral_peaks_threshold;
const char * spectral_power_edges;
} ei_dsp_config_spectral_analysis_t;
typedef struct {
int axes;
float frame_length;
float frame_stride;
int fft_length;
bool show_axes;
} ei_dsp_config_spectrogram_t;
typedef struct {
int axes;
float frame_length;
float frame_stride;
int num_filters;
int fft_length;
int low_frequency;
int high_frequency;
float pre_cof;
} ei_dsp_config_audio_syntiant_t;
ei_dsp_config_flatten_t ei_dsp_config_23 = {
1,
8,
1.00000f,
true,
true,
true,
true,
true,
true,
true
#endif // EI_CLASSIFIER_MODEL_METADATA_H
Hi @louis
I have shared its okay you can join I do not mind, Live classification is running well, but getting the error on device simulations
@ookosoft I’ve tested this quickly on one of my targets, and the outputs match the studio. If you print like this:
// print the predictions
ei_printf("[");
ei_printf("%d ", (int)(result.classification[ix].value * 1000.0f));
ei_printf(", ");
#else
ei_printf(", ");
#endif
What does it say? I’m still suspecting the float printing.
Hi i have been experiencing the same issue, is it possible to see the output of the predictions you are getting ? @janjongboom
@marvin @ookosoft Interesting… If you run this on a real device, do you see proper results? Also, which Proteus model are you using? (Never used, but will send @louis on a mission to try it out
proteus version 8.9. selection of the board is STM32F401VE an arm cortex M4, 84MHz, 512K/96K should meet hardware requirements yes?
@marvin Yes, the capabilities shouldn’t be a problem, we run this on a wide variety of targets, and also in Renode without issue, so interesting to see what’s the difference with Proteus.
Sure @janjongboom, let me get a Windows Virtual Machine to install Proteus on.
@marvin @ookosoft, I let you know as soon as I have tested.
Regards
Do you mind sharing your stm32cube project.
I just installed a brand new Windows VM with Proteus on it
Yes I can share,do you need entire project or that the HEX to execute on proteus? I am also not seeing the option to attach files
I guess both would be best.
You can send me a zip file at louis@edgeimpulse.com
Once we will have the solution, we will share the solution here so everyone can enjoy it.
And could you explain a bit what steps you followed to run your program on Proteus so I can reproduce them please?
Followed the steps on running the model on edge impulse, However before generating code you also need to enable UART under connectivity.
On project settings C++ build settings, MCU post build outputs enable convert to HEX file
You will use the HEX when simulating in Proteus…Do you need the proteus steps?
