Increase a training time
Hi Edge Impulse team,
I wanted to ask if it would be feasible to extend the training time for a project(241656) on Edge Impulse for research purposes?
Thanks in advance!
Best regards,
Nurgaliyev Shakhizat
Hi @shakhizat,
Hi @shawn_edgeimpulse,
Thanks for your reply. Sure, I can.
We are at our research institute(https://issai.nu.edu.kz/), collected and generated the dataset with almost 70K audio samples in Kazakh language. We are implementing the keyword spotting classification for 28 classes. I recommended Edge Impulse to our team members because it is the best SaaS tool I have ever utilized for cloud-based machine learning. The deployment target will be an Arduino Nicla Voice board.
The project implementation is based on GitHub - IS2AI/Kazakh-Speech-Commands-Dataset: Kazakh Speech Commands Dataset. I can confirm here, that it is used for research purposes only, not commercial. You can check from our website it, that we are sharing our datasets globally for research needs.
If you require any further information, let me know.
Best regards,
Shakhizat
Sorry to disturb you again.
Could you help me with the endless building project in the deployment section? After 5-6 hours it states that job failed.
Best regards,
Shakhizat
