Include More & More Training Data
Request: Allow for mass disabling of data by percentage.
Motivation: Allows one to quickly iterate over Impulse properties to see how they affect the Training. Then interactively we will add in more data and the Model should improve
Example:
  • 3 Labels in dataset
  • Each Label has 1000 Samples
Option1:
  • Textbox: “Include x% of Samples for each Label”
    • x is user configurable
  • If x = 10, then the Model will be trained on 300 Samples or 100 Samples from each Label category.
Option2:
  • Textbox next to each Label: “Include x% of Label Samples”
Hi @MMarcial
Interesting what you are describing is called subset sampling.
Guess you could do this as is by setting the train / test split to Train:10% Test:90%. Then you will have faster training on your initial to get a gauge of the size of data required, but that is just a work around.
Let’s put a feature request together to be discussed with the ML and Studio teams. If you have any more detail or references to include please do.
