I am using the Spresense board and when I use Eon Tuner, I have a predicted latency of about 100ms for Classification. However, when generate an Arduino library and I go to run things, it is clocking in 1064ms. When I build the Spresense firmware, the classification latency is ~500ms.
Is there an easy way to pull the modification from the Firmware into the Arduino library to bring down the classification latency?
Why is the predicted latency in Eon Tuner off by so much? Is there anyway to get down to this latency?
Arduino Library:
Predictions (DSP: 7 ms., Classification: 1064 ms., Anomaly: 0 ms.):
Firmware:
Predictions (DSP: 6 ms., Classification: 530 ms., Anomaly: 0 ms.):
