Importing labelled object detection datasets from google cloud storage
I’m having trouble importing a labelled object detection dataset that i am storing in a google cloud storage bucket. When I import it, the images they appear fine but the label files get the error: “Failed to upload /tmp/ei-s3-sync-bmW1sg/training/_annotations.coco.json Missing protected header”.
When importing from a bucket it seems there are only 3 options after the bucket access has been verified: leave unlabelled, label from file name or label from folder name. Object detection needs bounding boxes so the labels are more complex but there doesnt seem to be a way to link to a labels file.
Initially i tried my own dataset, with a COCO JSON label file format. I tried calling the files “bounding_boxes.labels.json”, “bounding_boxes.labels” and “_annotations.coco.json”. I then downloaded the cubes object detection dataset which is used as the example for COCO label format, uploaded that to a google bucket but the labels are still not recognised.
Is there a way for edge impulse to automatically recognise and label object detection datasets when importing them from cloud storage?
EI automatically detected the label file in each of the test and train folders, and applies bounding boxes to images as labels
Files remain unlabelled
  • [ tick ] Always, but error messages seem to vary for the reason labelled file couldn’t be uploaded
Only tried from Google cloud storage bucket. Using the free tier of edge impulse
Hello @jameswithers,
Unfortunately, the custom object detection annotation formats only work with our CLI and EI Project Upload UI.
For now, you could either write a custom script to convert your COCO dataset to Edge Impulse or to use the CLI/Uploader UI.
