Ya Actually i was experimenting multiple things and then i was able to either not able to upload or achieve accuracy .
Now it has solved my problem . But thanks so much for the support.
@louis While deploying the model on Arduino IDE . In examples by default i am finding only
1.nano_ble33_sense_accelerometer
2.nano_ble33_sense_accelerometer_continous
3.nano_ble33_sense_camera
4.nano_ble33_sense_fusion
5.nano_ble33_sesnse_microphone
6.nano_ble33_sense_microphone_continous
Which is right one to use to draw inference .
Hello @Rishab96,
If you collect data from a custom sensor, I would use the static_buffer example, and modify the code to pass the data you collected into a buffer.
I would do something like that for your loop function (example with a custom accelerometer, thus 3 axis and three reading, in your case you probably only read one value):
void loop()
ei_printf("\n ---------------- \n Starting inferencing...\n");
delay(10);
ei_printf("Allocating buffer size...");
ei_printf("Done\n");
ei_printf("Sampling...");
static unsigned long acquisition_start = millis();
// read to the end of the buffer
buffer[ix + 0] = accel.getX();
buffer[ix + 1] = accel.getY();
buffer[ix + 2] = accel.getZ();
static unsigned long acquisition_end = millis();
static unsigned long acquisition_time = acquisition_end - acquisition_start;
ei_printf("Done in %d ms\n", acquisition_time);
signal_t signal;
if (err != 0) {
return;
ei_printf("Done...\n");
ei_printf("Running the classifier... \n");
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
@louis But i have not used any sensor for data collection instead i have trained a model using csv upload.
Hello @Rishab96,
I am not sure what you are trying to classify.
You can still use the static_buffer and copy-paste raw data obtained from the studio.
Please see: Arduino library - Edge Impulse Documentation
@louis Actually this is demo project that i am trying to do to show it to my manager . He wants me to implement this.I know this is simlpe problem to classify .But thanks for the support.
