I have around 8500 images, all relatively small (~5KB), divided into 5 labels. However, when importing the images one label at the time, it gets stuck importing the images. Is there some sort of limit on the amount of data you can import? All the images together are around 34MB.
Hi @wouter,
Do you have an error during the import?
If you are using the Web UI, can you give a try with the CLI uploader (https://docs.edgeimpulse.com/docs/cli-uploader)?
No there is no error, it just gets stuck. I am indeed using the web UI, but will try with CLI and let you know how that went.
Wouter
CLI does the trick. Thanks!
