Problem solved, thank you very much.
Hi @caifan ,
The cropping effect might be as a result of the Resize mode you selected when creating your impulse. To change it, go to Impulse Design > Create Impulse and choose “squash” as your resize mode.
“Fit to shortest axis” and “Fit to longest axis” usually tends to crop the image.
Let me know if this helps solve your problem.
Thanks,
Clinton
