I am trying to convert my tflite model that i trained on colab and saved to a compatible format for use on arduino, below is my code snippet;
model_output_type = ei.model.output_type.Classification(labels=my_classes)
deploy_bytes = None
try:
deploy_bytes = ei.model.deploy(model='/content/model.tflite',
                               model_output_type=model_output_type,
                               deploy_target='arduino-nano-33-ble-sense')
except Exception as e:
print(f"Could not deploy: {e}")
if deploy_bytes:
with open(deploy_filename3, ‘wb’) as f:
f.write(deploy_bytes)
However it takes about 6 minutes to complete the block and return an error saying;
Could not deploy: (500) Reason: Internal Server Error HTTP response headers: HTTP response body: No deployment exists, did you build yet?
How can i go about this, thank you
