Hello, I am currently importing the model into Keil and have completed it, but I am not sure how to call these functions to make the model run. Could you please tell me what I need to do? The code is as shown in my screenshot.Thanks for your help.
May I ask if I can deploy the Cube.MX CMSIS-PACK to RAM in MDK? I find it much more convenient to use Cube.MX CMSIS-PACK for deployment. I look forward to your reply. Thank you!
Since the board I am using is not the one provided by your company, could you please advise me on how to convert the data collected from my sensors into the corresponding feature data after I complete the model deployment? I noticed that the example only shows how to copy the raw feature data from Edge Impulse to Keil. What steps should I take to transform the data from my sensors into the corresponding feature data, as shown in the image below? I look forward to your response. Thank you!
I copied this original feature data from this location. What do I need to do to convert the corresponding sensor data into the feature data corresponding to the image? Thank you!
@sq18856514787
if you want, you can use just the raw data returned from sensor - but then the model should be trained with the same “raw data” - data format of training and when you run inference must be the same format to get good results.
