Hello Impulse Edge I have a sensor with 15 axes when using spectral analysis, only 3 axes are visible please help before i used everything was ok
Hello @norik.badalyan,
It looks like your axis names are the same right?
Could you try to rename them with:
accX1, accY1, accZ1, accX2, acc,Y2, accZ2, etc�
I am not sure what changed if it worked before though. Investigatingβ¦
Thanks, everything works, forgot and called everything with the same name, when you answered, looked at the old work and found accX, accY, accZ, accX1, accY1, accZ1 β¦
