please if someone can help me, i want to use fomo model btu i couldn’t find it in the models section, i only have mobileNEt versions and a EfficientNet B0 one, that’s it.
FOMO does call MobileNetV2().
However, un-understandably FOMO is called Object Detection (Images) when designing your Impulse.
Hello @ashref123,
As MMarcial mentionned, you first need to select the type of learning block you want to use. In your case, Object Detection (Images).
Then, in the left menu, after you extracted the features, you should see the “Object Detection” tab.
From there, you can then select a pre-trained different model:
I hope that helps,
