Hi rjames! this is how i’m creating the features array:
import serial
import time
ser = serial.Serial(“COM5”, 115200)
buffer = [1.8435, -0.6177, 1.3378, 0.7452, 1.4521, -0.1024, 0.0012, 0.6913, -1.6179, 3.6703, 1.6897, -4.1073, 6.1298, -2.5109, 2.1009, 8.4455, -2.7797, -0.3531, 9.5193, -1.9878, 0.3561, 7.9398, -0.0886, 0.2664, 5.1008, -1.0325, -0.3938, 1.5868, -1.0157, -1.2641, 0.4094, -1.0032, 1.1420, 0.4549, -0.7937, 0.0132, 2.7683, -1.8208, -4.6136, 5.3343, -2.2051, -2.1907, 7.0563, -0.9894, -0.4064, 8.2690, -2.6653, -0.2376, 7.2682, -2.1171, -0.5028, 5.5414, -1.3749, 0.0449, 2.7432, -0.9116, -0.4256, 1.5275, 0.3208, 0.1856, 0.4687, 0.5692, -0.7111, 1.2360, 0.6907, -1.3593, 5.9526, -1.2276, -0.1760, 5.6419, -4.4083, -1.6382, 9.2817, -2.5929, -0.0856, 8.7712, -0.9170, 0.1472, 6.4141, -0.9433, -0.2999, 4.0462, -0.7045, -1.0451, 1.2779, -0.6051, -0.8308, -0.0760, 0.1939, 0.1538, 0.6045, -0.7853, -0.4854, 2.3463, -2.3302, -3.9037, 6.1178, -0.1089, -0.6668, 8.3450, -1.3096, -0.2753, 8.8597, -2.8533, -0.1844, 7.5352, -3.0849, -0.2005, 6.5218, -1.6149, 0.1401, 3.1801, -1.5814, 1.6466, 0.9152, 0.5692, -0.1419, 0.0587, 0.8194, -0.7691, 0.8966, 1.8352, -2.0309, 5.0607, -3.2555, -0.1778, 5.3828, -4.3604, -0.5944, 9.4296, -3.2938, 0.6644, 8.9376, -1.1504, 0.1024, 7.1778, -0.1754, 0.4758, 4.1108, -0.8428, -0.6608, 1.0534, -0.6626, -1.8920, 0.4154, 0.0922, -1.8094, 0.3693, 0.0036, 0.0497]
while True:
buffer = [str(i) for i in buffer]
buf = ''
for i in buffer:
buf += i+','
buf = buf[:-1]
buf = buf + '!'
msg = ser.read(1)
receivedMsg = msg.decode('utf-8')
print(receivedMsg)
while receivedMsg != '~':
msg = ser.read(1)
ser.write(buf.encode())
msg = ser.read(100)
print(receivedMsg)
msg = ser.read(2000)
print(receivedMsg)
as for the code for the himax to get the characters 1 by 1 and convert the char to float, this is what i wrote:
hx_drv_uart_print("~");
while(hx_drv_uart_getchar(&get_ch) == HX_DRV_LIB_PASS){
if (get_ch == '!'){
break;
else{
v.push_back(get_ch);
hx_drv_led_on(HX_DRV_LED_RED);
char* a = &v[0];
int k=0, index=0;
float val = 0;
while(a[k] != NULL){
if(a[k] == '-'){
if(a[k+2] == '.'){ //if <10
val = (float)(a[k+1]-'0') + 0.1*(float)(a[k+3]-'0')+ 0.01*(float)(a[k+4]-'0') + 0.001*(float)(a[k+5]-'0')+0.0001*(float)(a[k+6]-'0');
val *= -1;
features[index] = val;
k+=8;
else { //if >=10
val = 10*(float)(a[k+1]-'0') + (float)(a[k+2]-'0')+ 0.1*(float)(a[k+4]-'0') + 0.01*(float)(a[k+5]-'0')+0.001*(float)(a[k+6]-'0')+0.0001*(float)(a[k+7]-'0');
val *= -1;
k+=9;
else{ //if not -ve
if(a[k+1] == '.'){ //if <10
val = (float)(a[k]-'0') + 0.1*(float)(a[k+2]-'0')+ 0.01*(float)(a[k+3]-'0') + 0.001*(float)(a[k+4]-'0')+0.0001*(float)(a[k+5]-'0');
k+=7;
else { //if >=10
val = 10*(float)(a[k]-'0') + (float)(a[k+1]-'0')+ 0.1*(float)(a[k+3]-'0') + 0.01*(float)(a[k+4]-'0')+0.001*(float)(a[k+5]-'0')+0.0001*(float)(a[k+6]-'0');
k+=8;
index++;
i managed to get the first few characters right (only first 2 elements) but after that everything is a mess…
