How to use two exported projects from the edge impulse in a single arduino code
I need to use two exported edge impulse projects in my RAK3112 which is ESP32 compatible. The issue I am gacing is the same name or fields in both the exported files that include a classification layer with the same name.
880958
I tried exporting the two projects from edge impulse and using them in the arduino project. But I am not able to segregate the classification block from both the files as the structure of both is same with same name but they have different features and impulse structure.
I want to use it for a project to detect and confirm an accident based on the IMU reading and confirmation via the model trained based on sound.
Not able to execute it.
  • Platform: [RAK3112]
  • Build Environment Details: [RAK3112 ESP_32]
  • OS Version: [e.g., Ubuntu 20.04]
  • Edge Impulse Version (Firmware): [v15 (Arduino library)]
Hi @ayushevon - welcome to the forum!
I haven’t done this specifically with Arduino libraries, but we do have a tutorial about how to do this with C++ libraries that can give you some insights: Run multiple impulses (C++).
If you are an enterprise user, you can push our custom deployment block example that does this: multi-impulse-deployment-block.
Lastly, we have a guide that explains the different ways to combine impulses: Combining impulses.
Hope this helps!
