How to use data from external sensor in Arduino Nano 33 BLE sense for machine learning
Hi, I want to know if its possible to use external sensors connected to analog input of arduino nano 33 BLE sense for machine learning.
I have collected the data from an external sensor via the analog port in arduino nano 33 BLE sense and the trained a model in edge impluse and build the arduino library.
How can I use the analog sensor data to make the real time prediction similar to the example using build-in sensors?
Hello @monunith
To forward your data to Edge Impulse directly using your board, you can use the data forwarder.
You can use something like that (I have not tested the code):
#define FREQUENCY_HZ        50
#define INTERVAL_MS         (1000 / (FREQUENCY_HZ + 1))
void setup() {
    Serial.begin(115200);
    Serial.println("Started");
void loop() {
    int sensorValue0, sensorValue1;
    if (millis() > last_interval_ms + INTERVAL_MS) {
        last_interval_ms = millis();
        sensorValue0 = analogRead(A0);
        sensorValue1 = analogRead(A1);
        Serial.print(sensorValue0);
        Serial.print('\t');
        Serial.print(sensorValue1);
Then, you can use the same method to fill your buffer when running the inference.
Hi Louis,
Thank you for the reply,
I have done the data collection and forwarding to the edge impluse. I have completed the training of the ml model and created the library. I am stuck at how to use the created library for implementing the project.
When i ran the example code that i got in the library the following error is coming as i have provided the data from a0 and a1 for the training but for running the library code i haven’t called a0 and a1.
“ERR: Sensors don’t match the sensors required in the model
Following sensors are required: a0 + a1”
Any suggestion or tutorials available on how to implement the code for the same.
Hello!
You could do something like the following in your loop function (again did not test). I used the generated Arduino example for the IMU and replaced the IMU data by AnalogRead:
    for (size_t ix = 0; ix < EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE; ix += 2) {
        buffer[ix] = analogRead(A0);
        buffer[ix + 1] = analogRead(A1)
    signal_t signal;
    if (err != 0) {
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions ");
    ei_printf(": \n");
        ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
#endif
Let me know if that helps.
Hi Louis,
Thank you. it worked.
