I have question please; I am working on code that deal with image make some processing on it. When I run my code on teensy 4.1(memory= 1M) the max size of image that I can upload is uint8_t image[200][200]. The memory of portenta h7 is (2M) so why I can not use image size like [300][300] or [250][250] for the same code?
Hi @m_lena
Welcome to the forum!
There is a note on our firmware about this, hopefully this can clarify things for you:
You get the above error when there’s not enough (contiguous) memory to allocate TFLite arena. This can be caused by different reasons
- Heap fragmentation
- Not enough RAM/heap.
In the case of (1) you may want to allocate the tensor arena statically by defining
"-DEI_CLASSIFIER_ALLOCATION_STATIC"inarduino-build.shorboards.local.txt. If the problem still persists, then it may be that there’s not enough RAM/heap for your model and this application. Currently the heap is placed in a512k RAM segment.
@mateusz fyi
