I made a crash classification model that detects two labels: ADL or FALL, download the binary which gives me edge impulse and it works correctly.
I want the label that comes out to be sent to an app via Bluetooth, that’s why I made the following sketch in Aruino IDE
#include "NDP.h"
#include "Nicla_System.h"
#include <ArduinoBLE.h>
// Alert Service
BLEService alertService("b6a9c10a-b242-4397-9afe-2688a86c8b5c"); // Bluetooth® Low Energy LED Service
BLEUnsignedCharCharacteristic alertCharacteristic("d86af06b-228d-4300-8f9f-ca30db6ee3ac", BLERead | BLENotify);
void blesend(char* label) {
Serial.print("Label received: ");
Serial.println(label);
if (strcmp(label, "NN0:ADL") == 0) {
alertCharacteristic.writeValue(1);
Serial.println("ADL Detected!!!");
NDP.noInterrupts();
nicla::leds.begin();
nicla::leds.setColor(green);
delay(200);
nicla::leds.end();
NDP.interrupts();
} else if (strcmp(label, "NN0:FALL") == 0) {
alertCharacteristic.writeValue(2);
Serial.println("FALL Detected!!!");
NDP.noInterrupts();
delay(200);
nicla::leds.end();
NDP.interrupts();
} else {
Serial.println("No match found.");
void ledGreenOn() {
delay(200);
nicla::leds.setColor(off);
nicla::leds.end();
void ledRedBlink() {
while (1) {
nicla::leds.setColor(red);
delay(200);
delay(200);
nicla::leds.end();
void ledBlueBlink() {
for (int i = 0; i <= 2; i++) {
nicla::leds.setColor(blue);
delay(200);
delay(200);
nicla::leds.end();
void setup() {
Serial.begin(115200);
// while (!Serial);
// Nicla System setup
nicla::begin();
nicla::disableLDO();
// nicla::enableCharging(100); // enabling the battery charger
// Neural Decision Processor callbacks setup
NDP.onError(ledRedBlink);
NDP.onMatch(blesend);
NDP.onEvent(ledGreenOn);
Serial.println("Loading synpackages");
// Neural Decision Processor firmware and ML model files loading
NDP.begin("mcu_fw_120_v91.synpkg");
NDP.load("dsp_firmware_v91.synpkg");
NDP.load("ei_model.synpkg");
Serial.println("packages loaded");
NDP.getInfo();
nicla::leds.end();
// NDP.configureInferenceThreshold(1088);
NDP.interrupts();
// Initialize BLE
if (!BLE.begin()) {
Serial.println("Starting BLE failed!");
while (1)
// BLE service and characteristics setup
BLE.setLocalName("FallDetection"); // Device Name
BLE.setAdvertisedService(alertService); // add the service UUID
alertService.addCharacteristic(alertCharacteristic); // add the alert level characteristic
BLE.addService(alertService); // add the alert service
// start advertising
BLE.advertise();
Serial.println("BLE advertising started");
nicla::leds.end();
void loop() {
BLEDevice central = BLE.central();
if (central) {
Serial.println("Connected to central device.");
ledBlueBlink();
//Test
alertCharacteristic.writeValue(0);
Serial.println("Sent test message.");
NDP.interrupts(); // Start inferencing
while (central.connected()) {
delay(1000);
Serial.println("Disconnected from central device.");
} else {
Serial.println("Waiting for central device...");
delay(1000);
First I uploaded the binary generated by edge impulse and then the sketch I made with arduino ide and the result is the following:
Loading synpackages
packages loaded
dsp firmware version: 19.2.0
package version: Model generated by Edge Impulse
pbi version: 3.2.3-0
num of labels: 2
labels: NN0:ADL, NN0:FALL
total deployed neural networks: 1
Sent test message.
In the app I have I only get 0 , no 1 (ADL) or 2 (FALL), any idea how I could fix this?. Thanks in advance
