I’m currently using data augmentation for training my model. This is the code used in advanced keras mode for augmentation which i added a few augmentations.
def augment_image(image, label):
# Flips the image randomly
image = tf.image.random_flip_left_right(image)
image = tf.image.random_flip_up_down(image)
# Increase the image size, then randomly crop it down to
# the original dimensions
resize_factor = random.uniform(1, 1.2)
new_height = math.floor(resize_factor * INPUT_SHAPE[0])
new_width = math.floor(resize_factor * INPUT_SHAPE[1])
image = tf.image.resize_with_crop_or_pad(image, new_height, new_width)
image = tf.image.random_crop(image, size=INPUT_SHAPE)
image = tfa.image.translate(image, [HSHIFT * tf.random.uniform(shape=[],minval=-1, maxval=1), VSHIFT * tf.random.uniform(shape=[],minval=-1, maxval=1)],interpolation='nearest',fill_mode='nearest')
# Vary the brightness of the image
image = tf.image.random_brightness(image, max_delta=0.2)
image = tfa.image.rotate(image, MAX_ROT_ANGLE * tf.random.uniform([], dtype=tf.float32),interpolation='nearest',fill_mode='nearest')
return image, label
train_dataset = train_dataset.map(augment_image, tf.data.experimental.AUTOTUNE)
I have downloaded the ipython notebook and i want to visualize the data augmentation which is going through.
I’m used to ImageDatagenerator() method of augmentation, there will be option to save in a dir in flow() api or flow_from_directory() api.
Is there way to save the augmented images using this method?
Thanks and Regards,
Ramson Jehu K
