#include <kimyoungmoon-project-1_inference.h>
#include <Arduino_LSM9DS1.h>
void setup()
Serial.begin(115200);
Serial.println(“Edge Impulse Inferencing Demo”);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
return;
void ei_printf(const char *format, …) {
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
void loop()
ei_printf("\nStarting inferencing in 2 seconds…\n");
delay(2000);
ei_printf("Sampling...\n");
IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
buffer[ix + 1] *= CONVERT_G_TO_MS2;
buffer[ix + 2] *= CONVERT_G_TO_MS2;
signal_t signal;
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
#error “Invalid model for current sensor”
#endif
I want to know how to operate the buzzer in the desired motion after machine learning.
