Hi Team,
You guys have been a great support. Really appreciate your work. Hope I’m not bothering you with too many questions.
I have annotated the dataset with the help of edge impulse for object detection problem. I want to train the model locally, so I have downloaded the image training data and image training labels which is in .npy format.
But when trying to load the dataset using
X = np.load('ei-test_tube_detection-image-X.npy')
Y = np.load('ei-test_tube_detection-image-y.npy')
Im facing the following error:
ValueError Traceback (most recent call last)
C:\Users\Public\AppData\Local\Temp/ipykernel_3364/3608968536.py in <module>
1 X = np.load('ei-test_tube_detection-image-X.npy')
----> 2 Y = np.load('ei-test_tube_detection-image-y.npy')
C:\Program Files\Python39\lib\site-packages\numpy\lib\npyio.py in load(file, mmap_mode, allow_pickle, fix_imports, encoding)
443 # Try a pickle
444 if not allow_pickle:
--> 445 raise ValueError("Cannot load file containing pickled data "
446 "when allow_pickle=False")
447 try:
ValueError: Cannot load file containing pickled data when allow_pickle=False
when I changed allow_pickle=True, the following error shows up.
UnpicklingError Traceback (most recent call last)
447 try:
--> 448 return pickle.load(fid, **pickle_kwargs)
449 except Exception as e:
UnpicklingError: invalid load key, '{'.
The above exception was the direct cause of the following exception:
OSError Traceback (most recent call last)
C:\Users\Public\AppData\Local\Temp/ipykernel_3364/2394030490.py in <module>
----> 2 Y = np.load('ei-test_tube_detection-image-y.npy',allow_pickle=True)
--> 450 raise IOError(
451 "Failed to interpret file %s as a pickle" % repr(file)) from e
452
OSError: Failed to interpret file 'ei-test_tube_detection-image-y.npy' as a pickle
How to load the dataset properly?
Thanks and Regards,
Ramson Jehu K
