I had this dataset downloaded from kaggle Indoor Objects Detection | Kaggle. Now I imported the pictures using “add existing data” and then I used the same feature to import labels but it’s showing error.
What is the error you see?
What is being executed when the error occurs?
Why do you think this is an error?
How did you import the labels, aka what method or procedure?
