I want to use the classification result as conditional (if(){}) parameter but not doing according to what is in the condition. and also I tried to Serial.print the classification.result[ix].value but it get error said no matching function for call to ‘arduino::UART::println(ei_impulse_result_classification_t&)’
I think I should create new function similar to print function in edge (ei_printf) to return the value, but I don’t know how to do it, or there is other solution? thanks in advance
If you want to grab the results classification you can do something similar to this which lights on a LED according to the classification results. It’ll give you an idea of how you can do something with the inference results:
