@rjames and @louis,
I am new to this TinyML and Edge Impulse and also the mentioned suggestions had more depth for me to consume.
Please take out a few minutes to go through this completely
Let me share a clear picture on what I am trying to do,
- Replicated Faucet audio classification model in EI
- Downloaded it as a C++ library.
- Followed the steps of approach in this link: https://docs.edgeimpulse.com/docs/deploy-your-model-as-a-c-library#create-a-makefile
- I gathered the main.cpp from the above mentioned link.
//main.cpp
#include <stdio.h>
#include “edge-impulse-sdk/classifier/ei_run_classifier.h”
// Callback function declaration
static int get_signal_data(size_t offset, size_t length, float *out_ptr);
// Raw features copied from test sample (Edge Impulse > Model testing)
static float input_buf[650] = {
-1.2499, 2.6768, 1.1546, 1.2468, 0.1183, -0.8606, 0.5514, -0.2750, 0.0352, 0.3802, 0.5430, 0.7830, -1.2270, -1.2546, 1.0519, 0.9000, 0.9674, -1.1848, 2.5841, 0.0741, 2.5454, -1.0782, -0.5412, 0.2570, 0.4586, 0.9596, -1.2188, 1.8183, -0.0931, -0.3918, -0.8104, 0.1562, -0.4991, 2.0208, 0.1922, -0.1200, 1.0671, -0.0562, 0.7494, -1.2340, 1.1815, 0.5990, 0.5382, 0.5212, 1.4408, 0.1510, 0.8330, 0.7513, -1.3334, -0.0265, 0.1758, -0.4882, -1.2242, 1.4035, 0.9996, 1.1769, 1.3072, 0.0218, -0.2021, -0.4501, 0.4524, -0.5441, -0.1965, -0.0056, 0.3877, -1.1437, 4.2140, -2.4306, 0.2165, 0.3267, -1.7997, 0.5458, -1.2066, -0.3113, 0.2499, 0.6801, 0.5837, -0.9795, 2.6413, -0.0557, 2.2754, 1.4062, -0.8807, -0.1946, -0.6090, 1.2311, 0.3741, -0.0561, -0.0350, -0.8655, 0.1114, 1.8805, -0.5963, 1.1900, 1.0974, 0.6903, 0.1867, -1.4703, 1.4858, 0.5481, -1.1022, -0.2616, -2.2635, -0.2390, 1.4730, -0.2513, 0.9505, 0.6225, 1.4774, 0.9229, -2.3754, -0.6783, 0.1134, -0.1160, -0.1137, 0.1516, 0.9437, 0.8827, -1.3946, -0.4132, 0.5484, 1.2453, 1.1125, -0.8156, 1.8219, 2.3342, -0.7384, -1.1011, -1.5087, 1.2643, 0.3536, -0.3045, -0.0212, 0.1655, 0.8864, -1.0856, -0.9615, 0.4886, 1.2751, 0.7456, 0.5725, 0.2442, 0.4768, 0.1025, 0.0006, -0.0542, -0.8683, 0.3927, -0.5324, -1.2179, 1.2343, -0.6452, -0.8230, 0.4758, 0.3758, 1.6095, -0.0201, -0.5008, 0.1145, -0.6909, -1.0810, 0.5425, -2.0149, 1.1232, 0.9431, 0.3365, 0.8646, 0.5684, 1.3273, -0.4915, -0.3801, -0.5082, -0.0903, 1.0598, -0.9106, -2.5140, 0.1106, 2.2969, 1.6695, 0.5234, 0.3436, 0.1380, -0.7403, -0.8652, -0.9501, -0.4303, 0.4751, 0.5735, -0.5013, 1.0516, 2.1936, 0.9314, 0.2836, -0.0919, -0.0361, -0.8775, -0.2045, 0.7949, 1.1270, 1.9294, 1.2358, -1.6967, 0.0842, 0.2908, -0.0840, -0.0643, -1.8292, -1.5515, -0.8808, 0.5194, 2.1695, 0.4121, 0.2605, -0.4362, -2.1628, 0.5926, 1.1842, -0.3003, 0.0787, -0.6281, 0.5580, -0.1636, -0.9416, 1.7522, 0.6324, 0.1720, -1.5335, -0.7481, -0.6037, -0.5189, -0.9699, 0.1952, 0.4837, 0.9873, -0.1894, -0.2698, -0.6465, -1.2588, -1.1057, -1.9926, 0.3584, 1.3303, 1.6969, 1.6630, 2.3969, 1.0194, 1.7365, 0.2493, -1.3367, -0.7779, -2.1001, -1.1804, -0.6956, 0.0188, -0.6577, -0.3948, -1.6594, 0.4544, 1.7831, -0.6245, 0.1458, -0.8502, -1.2709, -1.6817, -0.6232, 0.3814, 0.8332, -0.3402, 0.3171, 0.9163, 0.9521, 1.4266, -0.1704, -0.3607, -0.1349, 0.2583, 0.1369, -0.0131, -0.0818, 0.4627, -0.6596, -0.1702, -0.9831, -0.3631, 1.0384, 0.7707, -0.4708, -0.2704, -0.1136, -0.8103, 0.0101, 0.3382, 0.4356, -0.2629, -0.1764, -1.2728, -1.0845, 2.1899, 0.5767, 1.1988, -0.3980, 0.2624, -2.9597, -1.5673, -1.3922, -0.7308, -0.5957, -0.9519, 0.2713, 2.0375, 0.2142, -2.9868, 2.3510, -0.7834, 1.7764, 1.2349, 1.9651, 1.5906, -0.3835, -0.0288, -3.1145, -0.8341, 0.9734, 0.8341, 1.1604, 1.3021, -0.5905, 0.6965, 0.3989, -0.5648, -0.0349, 0.8043, 0.8938, 0.4020, -0.1462, -0.0393, -0.4184, -0.6744, 1.8611, -1.4521, -0.7900, -1.0773, -1.7050, 0.2634, 0.7486, 0.6555, -0.4314, 0.7569, 1.0457, -0.0088, 0.9132, 1.4880, -0.7121, 0.2905, -0.6281, 0.7429, 0.8565, -0.5003, -0.8603, -0.5170, -0.0183, 0.7349, 0.8274, -0.4880, 0.8017, -0.4514, -0.3329, -2.0800, -1.0348, -0.6140, 0.3866, -0.1326, -0.2271, -0.1285, -0.3148, -0.4459, -0.1219, 0.6354, -0.1489, 0.4691, -0.9354, -0.9899, 0.3824, 0.1153, 0.3246, -0.3345, -1.2648, 0.1997, 0.6062, 1.1702, 0.0790, 0.5600, 0.4204, -0.5946, 0.2163, -0.0961, 0.2981, -0.4108, -0.2814, -0.0356, 1.3450, -0.4295, -1.2381, 0.0949, -0.6943, -1.4402, -0.9571, 0.5443, 1.3988, 1.7599, -0.3452, 0.1238, 1.2957, 0.0297, 0.9006, 1.1569, -0.2574, -0.4848, -1.0703, -0.3549, -0.0611, 0.0307, 0.9121, -0.4069, -0.4893, 1.9344, -0.5394, -1.4208, 0.3240, -0.4135, -0.3014, -0.1434, 0.0769, -0.8301, -0.2821, 1.8794, -1.5452, 0.1619, 2.2248, -0.7793, -1.8576, 0.3719, -0.7187, 0.3127, -0.8896, -0.3688, 0.5978, -0.2874, 1.4370, -1.9091, -1.6616, -0.4741, -1.2252, -0.4728, 1.1965, -0.9816, 0.5569, -0.9560, 0.2558, 1.3678, -0.8981, -0.1574, -1.2985, -0.4120, -0.2215, -0.3412, -0.2679, -0.0667, -1.1195, 0.5197, -0.7390, 0.4548, 1.2960, 1.2947, 0.8558, -0.5529, -0.3056, -0.7635, -0.3799, -1.0532, -0.7795, -1.1192, 0.4260, -1.0613, 0.9841, 0.7645, -0.3807, 0.4231, -1.0814, -1.4607, -0.9601, 0.0613, 0.0268, -0.9215, -1.1432, 0.8836, -0.7038, -0.6130, -0.1840, 0.4796, 0.2611, 0.0499, -0.8922, -0.9245, 0.0673, 0.2462, 0.0818, -1.0521, 0.4610, -0.9995, 0.3457, 0.9988, 1.2092, 0.8116, -1.3501, -0.5111, -0.6645, -1.4294, -2.7762, -0.8232, -0.9438, -0.3502, -1.6607, 0.4585, -0.4028, 1.3806, 0.7213, -0.8204, 0.2284, 2.6747, 0.6207, 0.6294, -0.3174, 0.1515, -0.5546, 0.4160, 0.6910, 0.1201, 0.2506, 0.5360, 0.5020, -0.1456, 0.9495, -0.9575, 0.0657, -0.0933, 0.3204, 0.0795, 0.0935, -0.5939, 0.6895, 0.6346, 0.3688, 0.1165, -1.0502, 0.1651, -1.8505, -0.9234, 0.1954, -0.2101, 0.5405, 0.1018, 0.6296, 0.0792, 0.3710, 0.4573, -0.2430, -0.6287, 0.2346, -0.4585, 0.8887, 0.5686, 0.0048, -0.2555, 1.3553, 2.3282, -0.4329, -0.4439, -0.3061, -2.1576, -0.1185, 2.0488, -2.7107, -1.2404, -1.2380, -0.1493, -0.3911, 1.0617, 0.4128, -2.2894, -2.4464, 0.6353, 0.3029, 0.9588, -0.1824, -2.6501, 0.6866, 0.2896, 1.1264, -1.1399, -1.1297, 0.2234, -1.3528, -0.2605, 0.6773, -0.2977, -1.4831, -1.0822, -0.9874, -0.6242, -2.1775, 0.5092, -0.1660, -0.1334, 0.7685, -0.0576, -0.2275, 0.5766, 1.0440, 0.7241, -0.8571, -0.8936, -0.2402, -0.0721, 0.1206, -0.6613, -0.6396, -0.6692, -1.9594, -0.8309, 1.1808, 0.3220, -0.3420, 0.0383, 1.1603, 0.8848, -1.5100, -0.2180, 0.6974, -0.1491, 0.6866, 0.0809, -1.3089, 0.5330, -0.9887, 1.0428, -0.2611, 1.1262, 0.9829, -1.2083
int main(int argc, char **argv) {
signal_t signal; // Wrapper for raw input buffer
ei_impulse_result_t result; // Used to store inference output
EI_IMPULSE_ERROR res; // Return code from inference
// Calculate the length of the buffer
size_t buf_len = sizeof(input_buf) / sizeof(input_buf[0]);
// Make sure that the length of the buffer matches expected input length
if (buf_len != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
printf("ERROR: The size of the input buffer is not correct.\r\n");
printf("Expected %d items, but got %d\r\n",
EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE,
(int)buf_len);
return 1;
// Assign callback function to fill buffer used for preprocessing/inference
signal.get_data = &get_signal_data;
// Perform DSP pre-processing and inference
res = run_classifier(&signal, &result, false);
// Print return code and how long it took to perform inference
printf("run_classifier returned: %d\r\n", res);
printf("Timing: DSP %d ms, inference %d ms, anomaly %d ms\r\n",
result.timing.dsp,
result.timing.classification,
result.timing.anomaly);
// Print the prediction results (object detection)
printf(“Object detection bounding boxes:\r\n”);
for (uint32_t i = 0; i < EI_CLASSIFIER_OBJECT_DETECTION_COUNT; i++) {
if (bb.value == 0) {
continue;
printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#else
printf(“Predictions:\r\n”);
printf(" %s: “, ei_classifier_inferencing_categories[i]);
printf(”%.5f\r\n", result.classification[i].value);
#endif
printf(“Anomaly prediction: %.3f\r\n”, result.anomaly);
#endif
return 0;
// Callback: fill a section of the out_ptr buffer when requested
static int get_signal_data(size_t offset, size_t length, float *out_ptr) {
for (size_t i = 0; i < length; i++) {
out_ptr[i] = (input_buf + offset)[i];
return EIDSP_OK;
What changes do I have to make to this main.cpp in-order to perform live inferencing with Arduino Nano 33 BLE.
My final goal is to build the end application and its dependencies into a firmware and flash it on the board. (I know there is a firmware readily available but I wanted to experiment this approach).
Kindly help me out with this.
Thanks,
LN
