I use edge impulse for my project, it should recognize tomatoes on raspberry py, and I need that when raspberry pi sees a tomato, it will send a signal to the Arduino, but how can this be done if edge impulse can only be launched on the command line.
Hi @4our5ive,
You do not need to use the command line for Edge Impulse. There are a number of ways to run your ML model on a Raspberry Pi, including a C++ library, Python, Go, and Node.js libraries, WebAssembly, and Docker container.
sorry, but i couldn’t find on the internet hot to run it in python or c++m can you tall me or give a link how to do this
Hi @4our5ive,
I linked to each of the tutorials in my comment above. For C++, I recommend As a generic C++ library - Edge Impulse Documentation
For Python: Linux Python SDK - Edge Impulse Documentation
Sorry, but I didn’t understand how to run image recognition on it and read the data in it
Hi @4our5ive,
Here is an example of how to capture an image from a webcam on the Raspberry Pi and then run inference to classify that image using the Edge Impulse Python library: https://github.com/edgeimpulse/linux-sdk-python/blob/master/examples/image/classify.py
