First of all, I am very grateful to edge impulse for its contribution to the development of neural networks.I am currently working on a module for human motion recognition based on acceleration.My ultimate goal is to use the arduino nano 33 ble to collect and recognize motion data, and output the results through the pins on the module to achieve the output of the detection results.However, I still have some questions and difficulties。
1、Use arduino ide to verify the network (by inputting characteristic data), but how to realize continuous data collection and motion detection through arduino IDE? Is it possible to achieve my request only through CLI (I saw it in some topics)?
2、How can I make the module work automatically when it is powered on and work offline ,instead of connecting to the computer and inputting instructions to start the module every time?
3、How can I use the pins of the module to output the test results (instead of the micro usb port)?
Hi @angfan123,
For 2 and 3: export as Arduino library from Deployment, then add the Library to the Arduino IDE via Sketch > Include library > From ZIP file. Then find the example sketch under File > Examples > Your project name > nano_ble33_sense_accelerometer. This is an Arduino sketch that you can modify to control pins and it starts automatically in inference mode.
For 1 try this (replace #include <continuous_gestures_demo_inference.h> with the header name you find from the example above):
* Copyright (c) 2020 EdgeImpulse Inc.
* SOFTWARE.
#include <Arduino_LSM9DS1.h>
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
void setup()
delay(5000);
Serial.begin(115200);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
return;
inference_thread.start(&run_inference);
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
void run_inference()
// wait until we have a full buffer
delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
while (1) {
// copy the buffer
float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
signal_t signal;
int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
#endif
delay(run_inference_every_ms);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
while (1) {
// roll the buffer -3 points so we can overwrite the last one
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
// read to the end of the buffer
IMU.readAcceleration(
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1]
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] *= CONVERT_G_TO_MS2;
// and wait for next tick
uint64_t time_to_wait = next_tick - micros();
delay((int)floor((float)time_to_wait / 1000.0f));
delayMicroseconds(time_to_wait % 1000);
#endif
Note that you’ll need to do some averaging here to make sure transitions between motions are handled properly (e.g. look at the last 10 inference results and only do something when 70% of them are the same). I’ll add this sample as well to our Arduino library exports.
Thank you very much, I will study your reply carefully next, thank you
