How to convert .lite to .tflite file to be used in Android app?
Using the file as a wake-word in a project/app for the visually impaired.
Wake-word
A .lite file is the same as a .tflite file. You can simply rename the extension. See this thread for more info: android - What is the difference between the .lite and the .tflite formats - Stack Overflow.
Note that you will need to make sure that the version of TFLite used to convert the model to .lite/.tflite is the same version of the TFLite used in your Android App.
- whats is the difference .lite and .eim file?why is we can’t directly use .lite for example using python linux sdk?
- can we see what’s inside that both file?
Hi @devis,
You can read more about eim files here: Edge Impulse for Linux - Edge Impulse Documentation
EIM files are compiled models (including DSP) and hardware optimized for Linux-based systems.
TFLite models only contain the Neural Network part, you can load them using the TF Lite interpreter.
Hi, Thanks for your responses.
I used the float32 .lite wake-word model file (c.f. Login - Edge Impulse) & loaded in an android app with the following block of code:
private static MappedByteBuffer loadModelFile(AssetManager assets, String modelFilename)
throws IOException {
AssetFileDescriptor fileDescriptor = assets.openFd(modelFilename);
FileInputStream inputStream = new FileInputStream(fileDescriptor.getFileDescriptor());
FileChannel fileChannel = inputStream.getChannel();
long startOffset = fileDescriptor.getStartOffset();
long declaredLength = fileDescriptor.getDeclaredLength();
return fileChannel.map(FileChannel.MapMode.READ_ONLY, startOffset, declaredLength);
However, this gives me following errors when I run the Android app with various files:
Internal error: Unexpected failure when preparing tensor allocations: tensorflow/lite/kernels/reshape.cc:69 num_input_elements != num_output_elements (172240 != 650)
Node number 0 (RESHAPE) failed to prepare.
Internal error: Unexpected failure when preparing tensor allocations: tensorflow/lite/kernels/reshape.cc:69 num_input_elements != num_output_elements (180320 != 650)
tensorflow/lite/kernels/reshape.cc:69 num_input_elements != num_output_elements (16164 != 650)
What did I miss here??
Quick follow up, we just posted a blog and guide together, with help from the embedded team on C++ and NDK for Android Studio - Getting Started with Android Studio and Edge Impulse
Hope this helps!
