Hi im not able to connect sparkfun edge board as it is not there in the list of officially supported list.
I was running commands on linux to connect it to edge impulse but I was getting error.
for $edge-impulse-linux output was:
Failed to initialize linux tool Error: Cannot find any webcams.
for $edge-impulse-data-forwarder output was
[SER] could not find any devices connected over serial port
[SER] Retrying in 5 seconds
the edge-impulse-linux command is probably not the one you are looking for as this one is to connect your machine (your linux or macos system to Edge Impulse).
The data forwarder is probably the one you should use.
I am not familiar with sparkfun edge board but can I make sure you can see from your computer the serial output of that board?
It says load an application on your dev board but what application should I load? Should I load those examples? or something else particularly for Sparkun edge- Apollo 3 blue?
