I used edge impulse to train the voice recognition model. I find the sampling time is quite fast and in 1 minute the number of samples taken is quite a lot. I want to change two house parameters, how do I do that?
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK 0
#define EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW 4
#include <PDM.h>
#include <khoaluan1_inferencing.h>
#include <HardwareSerial.h>
/** Audio buffers, pointers and selectors */
typedef struct {
signed short *buffers[2];
unsigned char buf_select;
unsigned char buf_ready;
unsigned int buf_count;
unsigned int n_samples;
} inference_t;
static inference_t inference;
static bool record_ready = false;
static signed short *sampleBuffer;
static int print_results = -(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW);
void setup()
Serial.begin(9600);
Serial1.begin(9600);
while (!Serial);
pinMode(LED_GREEN, OUTPUT);
ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) /
sizeof(ei_classifier_inferencing_categories[0]));
run_classifier_init();
if (microphone_inference_start(EI_CLASSIFIER_SLICE_SIZE) == false) {
ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
return;
* @brief Arduino main function. Runs the inferencing loop.
void loop()
if (!m) {
return;
signal_t signal;
signal.total_length = EI_CLASSIFIER_SLICE_SIZE;
signal.get_data = µphone_audio_signal_get_data;
ei_impulse_result_t result = {0};
EI_IMPULSE_ERROR r = run_classifier_continuous(&signal, &result, debug_nn);
if (r != EI_IMPULSE_OK) {
return;
if (++print_results >= (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)) {
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
int pred_index = 4; // added, Initialize pred_index
float pred_value = 0.8; // added, Initialize pred_value
ei_printf(" %s: %.5f\n", result.classification[ix].label,
if(result.classification[ix].value > pred_value)
pred_index = ix;
pred_value = result.classification[ix].value;
sendData(pred_index);
ei_printf(": \n");
ei_printf("%d",pred_index);
#endif
print_results = 0;
* @brief PDM buffer full callback
* Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
int bytesAvailable = PDM.available();
// read into the sample buffer
int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
if (record_ready == true) {
for (int i = 0; i<bytesRead>> 1; i++) {
inference.buffers[inference.buf_select][inference.buf_count++] = sampleBuffer[i];
if (inference.buf_count >= inference.n_samples) {
inference.buf_select ^= 1;
inference.buf_count = 0;
inference.buf_ready = 1;
* @brief Init inferencing struct and setup/start PDM
* @param[in] n_samples The n samples
* @return { description_of_the_return_value }
inference.buffers[0] = (signed short *)malloc(n_samples * sizeof(signed short));
if (inference.buffers[0] == NULL) {
return false;
inference.buffers[1] = (signed short *)malloc(n_samples * sizeof(signed short));
if (inference.buffers[1] == NULL) {
free(inference.buffers[0]);
return false;
sampleBuffer = (signed short *)malloc((n_samples >> 1) * sizeof(signed short));
if (sampleBuffer == NULL) {
free(inference.buffers[1]);
return false;
inference.buf_select = 0;
inference.n_samples = n_samples;
inference.buf_ready = 0;
// configure the data receive callback
PDM.onReceive(&pdm_data_ready_inference_callback);
PDM.setBufferSize((n_samples >> 1) * sizeof(int16_t));
// initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate
if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
ei_printf("Failed to start PDM!");
// set the gain, defaults to 20
PDM.setGain(127);
record_ready = true;
return true;
* @brief Wait on new data
* @return True when finished
bool ret = true;
if (inference.buf_ready == 1) {
ei_printf(
"Error sample buffer overrun. Decrease the number of slices per model window "
"(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)\n");
ret = false;
while (inference.buf_ready == 0) {
delay(1);
return ret;
* Get raw audio signal data
numpy::int16_to_float(&inference.buffers[inference.buf_select ^ 1][offset], out_ptr, length);
return 0;
* @brief Stop PDM and release buffers
static void microphone_inference_end(void)
PDM.end();
free(sampleBuffer);
void sendData(int pred_index){
switch (pred_index){
case 0: // "denchum"
Serial1.println("0");
break;
case 1: // "dieuhoa"
Serial1.println("1");
break;
case 2: // quattran
Serial1.println("2");
break;
case 3: //tivi
Serial1.println("3");
break;
case 4:
Serial1.println("4");
break;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
