Can you give me more detailed information about edge-impulse-data-forwarder?
For example, the code implementation.
Hi @davwang,
You can have more details in our documentation:https://docs.edgeimpulse.com/docs/cli-data-forwarder
The source code is also available on GitHub: https://github.com/edgeimpulse/edge-impulse-cli/blob/master/cli/data-forwarder.ts
When I used the edge-impulse-data-forwarder tool, I found that there is one requirement about this tool.
Because I upsent the serial data every 6 seconds, there is some interval in the data sequence I can not handle very well.
Is there some method ? Which can be used for complete data sequence?
Hi @davwang,
You can force the frequency of the data forwarder if it cannot be detected correctly, ie: edge-impulse-data-forwarder --frequency 1 (1 Hz frequency).
I mean that if the serial data have some interval between two sequences, are there any methods for handling? For example, if the tools send a command to the device I developed, then the serial data will be upsent to this tool.
It would be best to capture different samples if you have a break in your sequence.
What you can also try is the Crop/Split function in the Studio:
I know your method “crop and split”, but I think it is not the optimal method for this condition.
Maybe there are some other methods for this.
@davwang Three options:
- Use a higher priority thread (if that’s available) to make sure you always keep printing. Not sure on the target, but typically you can set a hardware ticker that fires an interrupt which always has priority, and write then.
- An alternative way is not using the data forwarder but just writing CSV files over serial (e.g. https://docs.edgeimpulse.com/reference?_ga=2.177157157.1890775457.1631454239-1252652237.1574934249#importing-csv-data) then you’re in full control over the data. Not sure if this fixes your artefacts.
- Don’t send the data every 6 seconds while you’re capturing data with the data forwarder
Thanks for your help. I have found that the platform has been updated for these equal samples.
Hi, I am new, and encounter this problem which sampling will not start after collecting about 3minutes of data
Thanks for your reply. I was trying out the nano ble 33 audio tutorial, capturing multiple voice samples and sampling somehow stopped after successfully collecting several samples. I closed the terminal, reconnect to Edge, and it works again. I guess I am ok now.
Thanks again for following up
