Hi need some help.
Now I have trained a model on the edge impulse using Arduino Nano ble 33 sense my project is to use accelerometer( LSM9DSI) that can recognize hand gesture when moving hand to up the car move foreword when moving hand down the car goes backsword and when i move my hand to the right the car turn right . Now I want to call this model on Arduino IDE and write a program to control the the car using of Arduino nano 33 ble sense development board. After I follow the steps in the document to convert the pulse into C + + source code, I donât know how to take the next step. I hope you can give me some advice. What can I do next?
#include <joker44project-1_inference.h>
#include <Arduino_LSM9DS1.h>
/* Constant defines -------------------------------------------------------- /
#define IN1 7 //K1ăK2 motor direction
#define IN2 8 //K1ăK2 motor direction
#define IN3 9 //K3ăK4 motor direction
#define IN4 10 //K3ăK4 motor direction
#define ENA 5 // Needs to be a PWM pin to be able to control motor speed ENA
#define ENB 6 // Needs to be a PWM pin to be able to control motor speed ENA
/ Private variables ------------------------------------------------------- */
@brief Arduino setup function
//motor control/
void go_ahead() //motor rotate clockwise -->robot go ahead
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, LOW);
delay(2000);
void go_back() //motor rotate counterclockwise -->robot go back
delay(2000);
void turn_right(int t) //left motor rotate clockwise and right motor rotate counterclockwise -->robot turn right
digitalWrite(IN4,LOW);
/*set motor speed */
void set_motorspeed(int lspeed,int rspeed) //change motor speed
analogWrite(ENA,lspeed);//lspeed:0-255
analogWrite(ENB,rspeed);//rspeed:0-255
void setup()
Serial.begin(115200);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
return;
@brief Printf function uses vsnprintf and output using Arduino Serial
@param[in] format Variable argument list
void ei_printf(const char *format, âŚ) {
static char print_buf[1024] = { 0 };va_list args;
va_start(args, format);
va_end(args);if (r > 0) {
Serial.write(print_buf);
/L298N/
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);set_motorspeed(255,255);
//go ahead 5s
go_ahead();
delay(2000);
//go back 5s
go_back();
delay(2000);//turn right 5s
turn_right(2000);
- @brief Get data and run inferencing
@param[in] debug Get debug info if true
void loop()
ei_printf("\nStarting inferencing in 2 secondsâŚ\n");
delay(2000);
ei_printf("Sampling...\n");
IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
buffer[ix + 1] *= CONVERT_G_TO_MS2;
buffer[ix + 2] *= CONVERT_G_TO_MS2;
signal_t signal;
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
#endif
#error âInvalid model for current sensorâ
#endif
