I have trained a object detection model by selecting MobileNetV2 SSD FPN-Lite 320x320. The model has TFLite_Detection_PostProcess layer at the end of the model, which outputs 4 outputs as shown in the image below:
I exported the project as c++ library without compiling with EON compiler. As i looked into the sdk, the allopsresolver didn’t have Detection_PostProcess operator, it was commented out though and EI_CLASSIFIER_ENABLE_DETECTION_POSTPROCESS_OP was not defined as well.
I have seen before that if a operator is missing in the resolver, error would through out that operator is missing, In this case i wonder how it works? Please can anyone explain how it is done.
Thanks for your question! If you’re not using EON you’ll need to add EI_CLASSIFIER_ENABLE_DETECTION_POSTPROCESS_OP to your compiler flags to ensure the op is available. There’s an example of this in our Example Standalone Inferencing repos:
