How can I upload my pipeline model to edgeimpulse project?
Hello, I’m trying to upload simple model to edge impulse directly. But It can not be uploaded by direct model upload menu from my project. How could I upload my model?
The code below is what I am trying.
(onnx_upload_test - Pretrained model - Edge Impulse
import numpy as np
from sklearn.pipeline import Pipeline
from sklearn.preprocessing import StandardScaler
from sklearn.svm import SVC
from skl2onnx import convert_sklearn
from skl2onnx.common.data_types import FloatTensorType
Sample data for training
X_train = np.array([[1, 2, 3, 4, 5], [2, 3, 4, 5, 6], [3, 4, 5, 1, 2], [4, 5, 6, 7, 8], [5, 6, 7, 8, 9]])
y_train = np.array([0, 1, 2, 0, 1])
Create the pipeline
pipeline = Pipeline([
(‘scaler’, StandardScaler()), # StandardScaler
(‘svc’, SVC()) # SVC with probability
Fit the model
pipeline.fit(X_train, y_train)
evaluation
X_test = np.array([[1, 2, 3, 4, 5], [3, 4, 5, 1, 2], [5, 6, 7, 8, 9], [4, 5, 6, 7, 8]])
y_test = np.array([0, 2, 1, 0])
print((X_test))
print((pipeline.named_steps[‘scaler’].transform(X_test)))
print(pipeline.predict(X_test))
score = pipeline.score(X_test, y_test)
print(“pipeline score:”, score)
Convert the pipeline to ONNX
Set the input shape to a fixed size (e.g., [1, 5] for batch size of 1)
initial_type = [(‘float_input’, FloatTensorType([1, 5]))]
final_types = [(‘output_label’, FloatTensorType([1, 1])), (‘output_probability’, FloatTensorType([1, 1]))]
onnx_model = convert_sklearn(pipeline, initial_types=initial_type, final_types= final_types)
Save the ONNX model
with open(‘svc_pipeline.onnx’, ‘wb’) as f:
f.write(onnx_model.SerializeToString())
  1. making pipeline model
  2. making onnx file from the code
  3. upload onnx file to the project
simply upload
Creating job… OK (ID: 25546624)
Scheduling job in cluster…
Container image pulled!
Job started
Converting ONNX model…
Job started
INFO: No representative features passed in, won’t quantize this model
Trying conversion using onnx2tf…
Grabbing input information…
No input shape conversion needed
ERROR: Scaler OP is not yet implemented.
Grabbing input information OK
Conversion using onnx2tf failed
Trying conversion using onnx-tf…
File “convert-via-tf-onnx.py”, line 68, in
ei_tensorflow.model_conversion.onnx.onnx_to_tflite(args.onnx_file, file_float32, file_int8,
File “/app/./resources/libraries/ei_tensorflow/model_conversion/onnx.py”, line 77, in onnx_to_tflite
onnx.checker.check_model(onnx_graph)
File “/app/.venv-onnx-tf/lib/python3.8/site-packages/onnx/checker.py”, line 106, in check_model
C.check_model(protobuf_string)
onnx.onnx_cpp2py_export.checker.ValidationError: Your model ir_version is higher than the checker’s.
Conversion using onnx-tf also failed, cannot use this ONNX file - contact your solutions engineer, or post the logs on the forum.
Converting ONNX model failed, see above
Job failed (see above)
  • [O] Always
  • Just website
Nothing
Hi @ecekim - the short answer is that arbitrary Scikit-learn pipelines are not currently supported.
There is a specific subset of classical ML models that are supported, which can be found in the Supported classical ML algorithms section of our Classical ML doc.
