How can I send a message in serial monitor once an object has been detected an X amount of times
Let’s say I’ve detected an object a set number of times, like 3, how do I make it send a message in the serial monitor, such as “detected”?
Basically once an object has been detected a set number of times, it sends a message in the serial monitor here it serial communicates with an arduino uno to move multiple motors.
 * SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
#include <cool_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
    Serial.begin(115200);
    while (!Serial);
    else {
    ei_sleep(2000);
* @param[in]  debug  Get debug info if true
void loop()
        return;
    if(snapshot_buf == nullptr) {
        return;
    ei::signal_t signal;
        free(snapshot_buf);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Object detection bounding boxes:\r\n");
        if (bb.value > 0.995) {
            continue;
        ei_printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#else
    ei_printf("Predictions:\r\n");
        ei_printf("  %s: ", ei_classifier_inferencing_categories[i]);
        ei_printf("%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
    ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
    ei_printf("Visual anomalies:\r\n");
    for (uint32_t i = 0; i < result.visual_ad_count; i++) {
        ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
        if (bb.value == 0) {
            continue;
                bb.label,
                bb.value,
                bb.x,
                bb.y,
                bb.width,
                bb.height);
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    if (err != ESP_OK) {
      return false;
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
    bool do_resize = false;
    if (!is_initialised) {
        return false;
    if (!fb) {
        return false;
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
        do_resize = true;
    if (do_resize) {
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        out_buf,
        img_width,
        img_height);
    return true;
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        // Swap BGR to RGB here
        // due to https://github.com/espressif/esp32-camera/issues/379
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#endif
Hey @heymanhowsitgoing , did you figure out how to send the message ?
