Himax WEI-I Plus supported by Edge Impulse
Running machine learning on embedded devices with scarce resources is one of the most exciting developments of the past years, allowing users to detect complex motions, recognize sounds or classify images. To make it possible to build and run these models on the smallest of form factors, we’ve partnered with Himax to support the new Himax WE-I Plus EVB board.
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/himax-wei-plus
Any suggestions @mathijs for best resolutions to make the impulse for the Himax WEI-I? The default seems to suggest 96x96 pixels.
Yeah 96x96 in grayscale works well
